Old 06-03-2010, 07:27 PM   #1
1977 25' Tradewind
Prince George , Virginia
Need Help with 12volt lights
I have replaced our battery and now it is dead..We have a 1978 Tradewind Landyacht 25 foot with rear bath..I am trying to find out if the lights are susposed to run off 12 volt and elect when it is pluged up to elect.our elect panel is located in the bathroom closet..and the 12 volt is behind the couch in living room..all fuses look good but the battery keeps going dead..the battery went dead after about 6 hours but there wasnt a light on when we left the trailer.Could someone please help me?We do not know anything about this Airstream.. but I am trying to learn..we have it set up in a camground and go every week to stay in it..
bobsbabe2 is offline   Reply With Quote
Old 06-03-2010, 07:42 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Your trailer lights all run on 12v.
It sounds like your battery isn't charging while you're trailer is plugged in. You have either a univolt or some other charger in your Airstream. Check to see if it's working. If it's not, it's either dead or it's not getting power from the main fuse panel. You can check this by simply checking the univolt/charger output to the battery with a voltmeter. It should be reading about 14volts while charging.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-04-2010, 11:36 AM   #3
1977 25' Tradewind
Thank you
Thank you for the help we will try this on the weekend..
Nancy
Old 06-06-2010, 05:41 PM   #4
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
You need a test lamp.
Take a 12 volt tail light bulb and solder a wire on the side and on the bottom connection. Then solder alligator clips to the wires. Then hook this between the battery and one battery cable. If everything is off, the light will be off. If the light is on, go around and explore the trailer to find out what is using power. You can use a volt meter for this but you can see the light easier from far away.
Good luck!
cosmos is offline   Reply With Quote
12v
12volt charger for sale ctdair Batteries, Univolts, Converters & Inverters 0 11-07-2009 01:43 PM
No 12Volt Power from Transformer JuliaPowell Batteries, Univolts, Converters & Inverters 4 07-09-2007 12:37 PM
Where is my 12volt fuse panel??? Blu_Hwy_Lady Electrical - Systems, Generators, Batteries & Solar 5 07-02-2006 12:37 PM
what operates on original 12volt? tinsltootsie Electrical - Systems, Generators, Batteries & Solar 8 05-25-2005 06:52 AM
