10-19-2014, 08:35 PM
1965 17' Caravel
Curtis Wright
San Marcos
Need electrical help on 1965 Caravel please
i hope y'all can help me. i am trying to get my 1965 caravel ready to go on the road. it didnt have a battery when i bought it and an electric hot water heater had been installed. i used it as a bedroom at my kids house for a couple of years and the electrics worked fine when connected to 120V. i now what to go on the road and would like to be able to use it with 12V. btw the lights use 12V car bulbs at present even with 120V.
here are some original pictures.
as you can see i have a rats nest of wires. it appears as though the original battery terminals can be seen to the right of the water pump. one wire is a thick red wire and the other a white wire that just grounds to the trailer wall.
i think that the red wire comes from the polarity rats nest. that box appears to have 120v entering it and a whole host of wires coming out that i cant figure out their use. they possibly go to the lights when used on 12v (???)
what is the use of the other box in front of the wheel well?
so where do i go from here?? lots of confusion on my part. what do i keep? what do i change? how do i add battery?
thanks for your input.
kevin
10-20-2014, 07:03 AM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Well, this will take some sorting out first. Attached is a wiring diagram from my 66 Trade Wind It may help you as Airstreams were built rather alike. However, 1966 was a significant model change, so I don't know.
Airstreams are wired to run on 12v and propane. At the time they called it "Univolt". I think Airstream was a pioneer in this type of RV electrical systems that is still used to day for the most part.
So the "heart" of your electrical system is a "converter". Yep, it converts 115v AC to 12v DC. Your water pump, vent fans, fridge, furnace fan, etc. run on 12v. Your trailer works on 12v while plugged in to 115v because your converter is working. Good! Your new 115v water heater won't work, and if you have an AC on the roof, it won't work either while on 12v.
My 66 trailer has a battery, and the red wire is on the + and the white wire is on the -. It appears you have identified these two wires. They ought to be in the 12ga or 10ga wire size. Pretty beefy wires.
There is a 12v fuse box in your trailer somewhere back there. There will be three 12v fuses protecting the 12v circuits from overload (like a failed fan motor.) You need to make sure those fuses are good.
So I guess I would unplug the 115v and hook up a 12v battery to your red wire (connect first) and white ground wire and look for smoke! If none, then
start trying out your 12v lights, fans, furnace, etc.
David
10-20-2014, 07:24 AM
Corona
kevin
That box is the original "univolt", but is actually a transformer that provides 12 and 19 volts AC.
The 12 volts is for the lights and the 19 volts is for the fan.
That system cannot charge the battery.
You can easily update the trailer by adding a regular "univolt" that provides DC for everything, fan motors included.
That transformer is actually rather expensive, but cheaper than a regular univolt. You probably could sell it on e-bay.
10-20-2014, 07:58 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
experience talking here
From my time with my Caravel I can tell you that you will be WAY ahead if you just start fresh with updated systems....period. It is not hard to do and not any more expensive than working and maintaining that old stuff.
Go to EBAY and get a new Progressive Dynamics, I use 9245) with a built in 3 way charge wizard capability. should be less than 100 dollars if you shop around. You will need a small ground terminal strip, a few circuit breakers and box, an auto reset (I use 35 AMP) circuit breaker, and an automotive blade type fuse panel.
Diagrams are around this site. Look at Best Converter and ask Randy for some advice if you need it. He can also provide all you will need....a little more expensive but well worth the total package he provides. Their web site has lots of info too.
Without a total rebuild of the Caravel go with the wiring thats there. Your going to get all sorts of well meaning info on aluminum wiring.....there are some easy ways to work with any concerns which you will hear about.
Your going to need a new battery..... period.
From what you said in your question about the 12v and 115v...the relation to the bulbs I think you should also read around this site and learn the relationship of the two electrical sources and their common point....the converter. That will answer many of your questions.
Good luck.
10-20-2014, 11:09 AM
1965 17' Caravel
Curtis Wright
San Marcos
thank you for information
thanks to those who replied and gave me direction. appreciated.
08-27-2018, 07:16 PM
1965 17' Caravel
dover
Good luck.
What is his website? How do I contact Randy?
08-27-2018, 07:18 PM
1965 17' Caravel
dover
Need to redo Electrical in 65 Airstream Caravel. No idea how to start! Any help would be appreciated. Thank you
08-27-2018, 07:20 PM
1965 17' Caravel
dover
kevin
Ours looks just like your pics. What did you end up doing? Any help would be appreciated.
08-27-2018, 08:35 PM
1986 34' Limited
1975 27' Overlander
Conifer
Hi dougandkim: Welcome to AirForums and the vintage Airstream hobby. Gee, a 65 Caravel, a very sought after vintage cutie.
So you have electrical problems. But what problems? You're gonna have to do some homework so you can describe what Forum members can help with. There is usually no reason to "redo electrical" in a vintage Airstream.
That said, here is just a few basics. Your Airstream is designed to operate off the battery in the back so you can have all the comforts of home on the 12v system. Then Airstream added a 120vAC battery "charger" to your trailer so you can charge the battery by plugging into "shore power". Then Airstream got a bit fancy and wired some 120vAC outlets in your trailer so you could plug in a coffee maker and the like if you are on "shore power".
So if you have no trailer lights, or fan, or water pump, or furnace fan, you don't have any 12v current being supplied from the battery. Tell us what the voltage reads across the terminals of the battery without being plugged into shore power. I would expect to see something like 12.5 volts
It may be your battery charger ain't working. Most folks call this device the "converter" because it converts 120vAC to 12vDC. So plug in your trailer and then measure the voltage across the battery terminals again. It should be maybe 14vDC.
With the trailer plugged in, plug in a lamp to all of the wall outlets. Does the lamp turn on? If not, then you are not getting power through the "power panel". Find the power panel, and reset the main breaker, and the two other breakers in the box. Do this by turning the breakers off, and then back on. Make sure they are set to "on". Now does the lamp light?
You also have to tell us what might work in your trailer on 12vDC. Any lights work? Any fans work? Does the water pump turn on? Can you tell us what doesn't work.
Report the results after doing these tests. Then folks more experienced than I can begin to help you diagnose the "electrical problems" with your Carvell
Hope this helps. I might add you tagged a 4 year old thread. It is pretty cold and some of the posters may have left the forums.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
08-27-2018, 09:17 PM
1974 Argosy 26
Morrill
, Nebraska
Instead of connecting a battery to an unknown system. I would recommend you use a battery charger like one used to charge a car battery.
The device in your coach is known as a converter. It does a similar thing when compared to a battery charger. But it is not very smart. It will cook your battery if it even works.
Test the DC system using an automotive battery charger. Fix any problems.
Then order a new converter and install it.
Ebay is a good source. Look for a Progressive Dynamics 9245 converter. It will be more than adequate for your needs.
Adventure RV usually has the best price. Look for their logo in the photo of the converter.
08-27-2018, 09:54 PM
New Borockton
, Alabama
I got your email Doug. I can't post pricing on a 9245 here but suffice to say it's not what you will find on auction sites but better. That said you won't have a warranty through PD from auction sites.
I don't think that is the product you need anyway but maybe. Sounds like you need more than just a stand alone converter and those are available. The distribution panel (AC and DC) likely needs upgraded as well. Hang in there and contrats on your new find.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
08-27-2018, 10:25 PM
1974 Argosy 26
Morrill
, Nebraska
Does anyone recognize how long this thread has been around? 2014
08-27-2018, 10:27 PM
1974 Argosy 26
Morrill
, Nebraska
I don't believe all things listed on ebay are at auction.
Many items simply have the price. You don't bid on those items. You just buy it like you would on Amazon.
08-27-2018, 10:32 PM
New Borockton
, Alabama
That is true and anybody can. They just won't honor the warranty because the sellers buy them out the back door from OEM and tear off the serial numbers to so the don't get caught.
PDI Disclamer
888-828-1893
Bestconverter.com
08-27-2018, 10:47 PM
1974 Argosy 26
Morrill
, Nebraska
PDI Disclamer
I doubt Adventure RV removes anything from the items they sell.
I have made numerous purchases thru them over the years and all came in OEM packaging that has not been opened.
08-27-2018, 10:56 PM
New Borockton
, Alabama
Ha, they were the original offenders! No retail box either when we purchased one and PD did too to check if it had a serial number. Twinkie, we sell lots of them but I hang with my Airstream friends to help them and answer questions because we've had 4 of them and we're Airstream people and want to help. It's not a big deal man. If you are their customer, It's okay. I just don't see them here helping folks and that's okay too.
888-828-1893
Bestconverter.com
08-27-2018, 11:09 PM
New Borockton
, Alabama
I didn't even think to check Twinkie but we're $4 less anyway on that product I didn't even know but what more do you want us to do to help Airstreamers?
888-828-1893
Bestconverter.com
08-28-2018, 03:17 AM
1967 17' Caravel
Oak Creek
Here is a wiring diagram from my 67 Caravel.
I had the same rats nest of wires shown in the pictures. The huge & heavy transformer behind the streetside wheel well goes when you put in the new converter.
I now have a new convertor & distribution panel installed. No more rats nest. It was not difficult to do.
Hope e diagram helps you.
kevin
08-28-2018, 03:25 AM
1965 17' Caravel
Curtis Wright
San Marcos
I know that this is an old thread that I started but glad to see it is still going. I landed up getting a new converter from Randy at best converters. He was fantastically helpful and I have to take exception to Twinkie who is suggesting that saving a few bucks
Is worthwhile. People like Randy and overlander ( not sure if they are the same person ) need every bit of our support for the amazing knowledge and information that they give us. Saving $4 is not a wise investment. In Texas we say that you dance with them that brung you to the dance.
I landed up just changing the converter to a good one and putting a battery in. Everything has continued to work for a number of years and many thousands of miles. Unless you are very proficient and want to do lots of work on it, I would consider this route. There is nothing to lose. A new converter and battery would be necessary if you redid it all anyway.
I would tighten all the screws on all the connections including the fuse box in the closet. I would make sure that all the wire nuts are tight. It is really easy to change the outlets if you want. There is no real reason that it shouldn’t work without tearing it apart.
08-28-2018, 07:26 AM
1974 Argosy 26
Morrill
, Nebraska
That's good to hear. Anytime money can be saved it is a good thing.
I did not intend for my recommendation of a converter to become an issue.
I am also here to help others.
