Old 11-12-2015, 07:49 AM   #1
1981 31' International
Need Battery
Just purchased a 1981 International 31 foot----with 2 hookups for batteries (2 Six Volts?)---but no batteries/ Does have the convertor plugged in that does appear to work// Will not travel much---and will be plugged in to 110 volts most of the time/ Suggestions on 1 or 2--- and kind of battery---CHEAP?? THANKS
Dancinman1 is offline   Reply With Quote
Old 11-12-2015, 08:10 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you will not need batteries for power, depending on your converter, you may or may not still need a 12v battery supply to have the converter convert. Sounds like you may get away with any 12v battery and probably only one. Ideally you would want a deep cycle battery rather than a starter battery for auto use. But this also may not be necessary for use as you describe. Plugging into 110 AC without any battery may be possible, but also may not be a good idea for your converter.
Battery Hold-down Strap Shorting Against Positive Battery Post rel Sprinter and B-van Forum 3 08-13-2013 10:32 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
