Old 12-21-2011, 04:10 PM   #1
1970 31' Sovereign
Burnsville , North Carolina
Need advice on installing a new converter
Hello out there. I am a new member and a new owner of a 1970 Sovereign. While I do have electric power (I am connected to my house) for both the 120AC and the 12V DC, from what I have read, I would be wise to replace the univolt with a new converter. Can anyone direct me to a place where I can find out what converter to purchase and the step by step instructions for doing this? I have been searching the forum and getting bits and pieces of info but am looking for more comprehensive advice. Thanks! Bill
CeloNC is offline   Reply With Quote
Old 12-21-2011, 04:15 PM   #2
dznf0g's Avatar
Oswego , Illinois
Contact these folks. I, for the life of me, have forgotten his name....someone else help. EDIT: Randy is who you want at BestConverter.com
They are most helpful.
BestConverter - Converters, Inverters, Electrical Supplies, Electronics
-Rich-
Old 12-21-2011, 04:19 PM   #3
dznf0g's Avatar
Oswego , Illinois
This is a thread on my swap-out.
http://www.airforums.com/forums/f449...ade-70932.html
-Rich-
Old 12-21-2011, 07:23 PM   #4
drunkensloth's Avatar
1965 17' Caravel
Knights Landing , California
I just bought a converter from randy at bestconverter few weeks ago. Great guy, very helpful.
drunkensloth is offline   Reply With Quote
Old 12-21-2011, 07:27 PM   #5
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Ditto on bestconverter. Randy will walk you through it.
Flynavy is offline   Reply With Quote
Old 12-22-2011, 12:30 AM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
Yes, Randy @ bestconverter.com does a great job out here in the west - I've bought a couple of C/Cs from him...
Closer to you in the East is RV Parts, RV Accessories RV Supplies Priced Low - they have all kinds of stuff for an RV, including a big selection of converter/chargers at what appear to be good prices...they have weekly specials that I've taken advantage of, and they ship promptly, etc...
Ray & Pat; Morada, CA
Old 01-12-2012, 07:29 PM   #7
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Need advice on Parallax 7300 converter replacement
I know next to nothing about converters, except that I understand the advantage of a "smart" converter (as I understand it, one that will sense the level of battery depletion and deliver an accelerated charge, if the depletion is significant). My current converter is a Parallax 7300 series that came with my '07 Bambi (19').
My power usage: We almost exclusively dry camp. I now rely on two 55 watt solar panels joined with a charge controller to keep my onboard batteries topped off, and a 1500 watt inverter for those occasions when I need alternating current. My interior and exterior (patio and step) lights are led. I don't run any appliances except the occasional laptop computer, and recharging computer and/or phones. Although I have a 2000 watt Honda generator as a backup, I'm probably going to replace it with a 1000 watt model (since I only need it to top off the batteries on days and/or locations with little sun, and I would appreciate the lighter weight of the 1000 watter!) In view of this info, what would be an appropriate replacement for the 7300 Parallax?
For extra credit, any opinions on Yamaha vs Honda as a replacement 1000 watt generator?
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 01-12-2012, 07:48 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look for a thread by "lucymcdog". She has installed converters in 2 different trailers. When she started she knew nothing about the electrical system in an Airstream. Be prepared for a long read.
Old 01-12-2012, 07:51 PM   #9
1974 Argosy 20
Kooskia , Idaho
I have always liked Progressive Dynamics 92xx series 3 stage converter chargers. If you go to a Honda 1000 watt generator, be aware that you may not use a PD 92xx larger than a 45 amp one, so it would be a 9245. The VA rating of the 9245 is under the VA rating of the Honda, but the next in the series, the 9260 takes more VA than the Honda 1000 will deliver. This is from actual experience with both units, the PD's and the Honda 1000.
If you use a 9245 you should be just fine, both in battery charging capacity and capacity of the Honda. I have no direct experience with the Yahama, but I believe it would behave about the same as the Honda.
I stress you need to consider the VA rating of the converter/charger and the VA rating of the generator. Usually we think of VA as equal to Watts, but in fact there is a sneaky little thing called Power Factor which mostly can be ignored on grid power, but cannot be ignored on inverter generators. Trust me here, it is a bit complex to explain, but a real issue in the field.
Old 01-12-2012, 08:16 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Power Factor is not an issue with single phase equipment. It only comes into play in multiple phase application. However, since you are dealing with alternating current and voltage which is produced with a sinusoidal sign wave the end result is not "true power" as it would be in a DC circuit. The term "apparent power" used to define the power in an AC circuit. "true power" is measured in "watts"; " apparent power" is measured in VA or volt/amps.
Just more useless information.
Old 01-12-2012, 08:36 PM   #11
JimGolden's Avatar
1977 31' Excella 500
OK, I had two semesters of electrical engineering in college but I have never heard of "power factor."
I have a PD4500 power station with the 60amp converter charger so that I can convert my 34 footer from 30amp to 50amp (though I'm not quite sure why it's called a 60amp...).
At any rate, will my Honda EU2000i be OK to recharge the batteries on this?
Maybe what I have is the 45XX series powerstation with the 9260 converter?
I thought I was OK here. Please help!!
- Jim
JimGolden is offline   Reply With Quote
Old 01-12-2012, 10:06 PM   #12
ESCAPE POD's Avatar
2007 19' Safari SE
Has anyone had any experience with the PowerMax PM3B-45 (45 Amp 3-Stage Converter Charger)? It's featured on Bestconverter.com, and is covered by a 3-yr warranty:
http://www.bestconverter.com/PowerMa...ger_p_412.html
Jerry & Susan
Old 01-12-2012, 11:31 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Jim Golden:
Look up the specs on your generator. It will tell you what the continuous load and the peak load ratings are. The 60 amp 12 volt converter will produce 720 watts of power. 60 x 12 = 720.
This stipulates the maximum load the converter can handle on the DC side of the converter. When the converter is at maximum load the current required on the 120 volt AC side of the converter will be 6 amps. 720 divided by 120 = 6. Since the converter is not 100% efficient the actual load on the AC side will probably be a little over 8 amps. Which translates to about 960 volt amps of power.
I doubt seriously that you will ever have the need to draw the full load from the 60 amp converter. Unless you add a lot of DC equipment to the trailer.
I am confused as to why you want to increase the AC side of the electrical from 30 to 50 amp. Are you adding a second air conditioner? Unless you have made or are planning to make significant changes to the 120 volt system. A 30 amp service will be more than adequate.
While the term watt or watts is commonly used to define power there is a big string attached. Watt is a term used to define power in a DC circuit. In a pure DC circuit to be more accurate.
The terminology that defines power in an AC circuit is volt/amps.
If you were to connect a 1,000 watt DC power source to a heating element it would produce about 30% more heat than an AC source rated at 1,000 volt/ amps.
AC generators should be and in industrial applications are rated in KVA terms (kilo/volt/ amps) or ( thousand/ volt/ amps) why the manufactures of small generators call out the capacity in watts is beyond me. When they call out the peak capacity of a generator at 2,000 amps and then deface its capacity to the "continuous" rating which is about 80% of the peak. That is the actual power rating of the generator.
Old 01-12-2012, 11:35 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Originally Posted by TG Twinkie
Jim Golden:
I meant to say derate not deface
Converter Conundrum benyeomans Batteries, Univolts, Converters & Inverters 15 07-29-2011 02:56 PM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 10:27 PM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 08:27 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
