Old 01-12-2012, 11:36 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I meant to say derate not deface.
Old 01-13-2012, 06:11 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by ESCAPE POD View Post
Has anyone had any experience with the PowerMax PM3B-45 (45 Amp 3-Stage Converter Charger)? It's featured on Bestconverter.com, and is covered by a 3-yr warranty:
Jerry,
Have had very good luck with this from Best Converter.
You can depend on Randy for appropriate recommendations.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-13-2012, 06:17 AM   #17
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Have my PowerMax sitting inside motorhome, will be installing it today hopefully. Univolt is not operating at full power any longer, figure 23 years is fine, especially when I have no idea what kind of history my rig has had.
I'll post here when I have installation complete.
And, from all that I've read, plus this unit was HIGHLY recommended by a member of the forum.
Thanks, Derek
Old 01-13-2012, 07:22 AM   #18
1970 31' Sovereign
Burnsville , North Carolina
Celo, NC
Thanks for all the help and encouragement. I may end up learning something about electricity as a result. Bill
CeloNC is offline   Reply With Quote
Old 01-15-2012, 11:22 AM   #19
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Anyone have experience with this?
Just heard back from Randy at BestConverters.com. Here's his recommendation:
"The 3 stage upgrade kits are the most popular for sure, they will give you much better charging profile and faster as well. The problem is the 55 amp unit will not run from a 1000 watt generator so you will need to either keep the 2000, or downsize the converter to the 45 or maybe even the 35. You should still be okay but will just take a little longer to charge your batteries. Minutes not hours."
Here are some links.
Magnetek/Parallax 6300/7300 Upgrade Kit
4600 series Upgrade Kits
Anyone use these units? I'll probably end up getting the 45 amp unit, and downsize my generator to 1000 watts (my back will thank me!).
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 01-17-2012, 08:51 PM   #20
Jerry,
Don't know anything about the P-lax with the up-grade kit.
But I had to replace the 7455 P-lax in the Classic, no float mode.
PFC
RLC
Old 01-18-2012, 08:56 AM   #21
dznf0g's Avatar
Oswego , Illinois
I am not sure I understand this. I upgraded to the Iota 55 amp model. The specs say it is 900W max. draw. And this would, I assume be for a relatively short time with a depleted (50%) battery and then start dropping off on it's consumption.
My assumptions are based on paper specs. I have not measured it, because I have a 2000W gennie anyway. I'd be curious though...I thought a 1000w Gennie could pull max load for a half hour to an hour without any problems??????
Edit: Hmmmm, I pulled out the owner's manual for the Iota DLS55...it is quite confusing.
Says:
Max amp draw: 13 (AC)
Max Watt draw: 950W (VA)=1460
I have never seen a watt rating and VA rating that far apart before. Kinda jibes with the amp rating though......misprint perhaps on the watts?
-Rich-
Old 01-18-2012, 09:36 AM   #22
IOTA questions????
dz,
Give Jay a call/email he was very helpful with questions I had on the same unit.
Jay Settlemyre
Iota Engineering Tech Support
IOTA Engineering Emergency Fluorescent Ballasts, Emergency Lighting Inverters, and AC/DC Power Converters
1-800-866-4682 ext 160
PFC
RLC
Old 02-11-2012, 02:07 PM   #23
Suzzeee's Avatar
2012 28' International
Antioch , SF Bay Area
Just have to pop in and say a big Thank You to everyone posting info on converters recently!! We're having a ton of work done on our 1992 Sovereign 21 and were already replacing the one battery and adding a second -- these threads made me realize we should also replace the converter which as it turns out is the original so 20 years old! Just ordered from BestConverter!!
2012 International Serenity 28
2012 Ford F150 EcoBoost TV
https://www.facebook.com/starlettediary
Suzzeee is offline   Reply With Quote
Old 02-11-2012, 03:26 PM   #24
Thumbs up
Suzzeee,
You can't go rong with Randy's advice.
Good luck with your project.
PFC
RLC
Converter Conundrum benyeomans Batteries, Univolts, Converters & Inverters 15 07-29-2011 02:56 PM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 10:27 PM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 08:27 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
