Old 09-24-2017, 06:10 AM   #1
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Need a pair of these for fusing battery
I am reworking my house batteries to get less losses to the inverter and I am starting with fuses at the battery terminals to eliminate a 300A circuit breaker that I think has excessive internal losses.
I am also going to upgrade, simplify & shorten the wiring.
I found these nice fuse to battery post package on a UK website and a pair with fuses and covers is a bit over $50 (US) but shipping is $80!
Anyone see this or similar in the US?
WayneG is offline   Reply With Quote
Old 09-24-2017, 06:22 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have seen those used on boats. Maybe someplace like West Marine might carry them.
MICHAEL
Old 09-24-2017, 07:26 AM   #3
1981 31' Excella II
New Market , Alabama
Can you get that fuse over here if you do blow one or it succumbs to corrosion?
Perry
Old 09-24-2017, 08:18 AM   #4
WayneG's Avatar
Scotia , New York
I looked over the marine site briefly and no luck, as for the fuse, it looks like a standard BUSS style fuse.
Old 09-24-2017, 08:37 AM   #5
WayneG's Avatar
Scotia , New York
This is the web site link in the UK
http://www.12voltplanet.co.uk/batter...ube-fuses.html
Old 09-24-2017, 09:42 AM   #6
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Is this the fuse going from battery to inverter?
If so I think the standard to use is a T-fuse, see link before.
Also, If your unit is original factory, it is likely the wiring is way to small, and you will get much better return and lower resistance by adding larger gage wire and a T-fuse...
http://www.airforums.com/forums/f449...ml#post2012527
Troutboy
Troutboy is offline   Reply With Quote
Old 09-24-2017, 09:47 AM   #7
2015 30' Classic
Pleasanton , California
Digikey has this stuff.
The terminal is found here, and the fuse is here.
In single unit quantities, the terminal is about $21 and the fuse about $8.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 09-24-2017, 09:59 AM   #8
1981 31' Excella II
After seeing the fuse close up, you don't want that right on the battery post. I would put it at the inside terminal end where it is protected from battery acid. Also it would take much less time to replace if it were in a terminal strip inside the trailer.
Perry
Old 09-24-2017, 10:48 AM   #9
WayneG's Avatar
Scotia , New York
That one is vertical, the one I need is horizontal. I have very little clearance above the battery post in the slide out drawer, that is what makes this method attractive.
As for the installation, it is home brew wiring to a 1800 watt inverter,converter and solar gear inside the MH, the batteries are in a sliding drawer below the inverter.
This is my setup: http://theouterlimits.ws/projects/ai...lar/Page2.html The current battery/inverter section is about 1/2 way down the page.
As for putting the fuse right at the battery, acid/corrosion wont be the biggest concern, I will use a 300 amp fuse on each of 2 batteries, then the cables go 6" to the battery switch, so it is messy using any other method
Old 09-24-2017, 02:09 PM   #10
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
May I suggest that you 'Keep it Simple'?
Buy a single 300 Amp fuse, or a couple of in line 150 Amp fuses,("Lift truck fuses"), that bolt onto any terminal; and put it at the battery on the Neg. Terminal.
If you use 150 Amp, put one on top of the other, or at least in parallel.
This will give the whole house, protection from a 'dead short'. eg: a wrench dropped on the bare wire somewhere.
Perry's idea might be worth looking into also.
MelGoddard is offline   Reply With Quote
Old 09-24-2017, 03:10 PM   #11
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Perry
First rule of circuit protection (i.e. fusing) is to put the fuse as close to the power source as possible to protect as much of the circuit (i.e. wire) as possible. For that criteria, on the battery terminal is perfect. Moving the fuse into the trailer would mean a chunk of wire was not protected against a short circuit. I wouldn't personally take that risk.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 09-24-2017, 03:41 PM   #12
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Just brainstorming here.
How about combing a Top to Side post battery adapter with a
Blue Sea MRBF fuse holder set on its side?
Greg
greghoro is offline   Reply With Quote
Old 09-24-2017, 03:50 PM   #13
WayneG's Avatar
Scotia , New York
Greg
Thanks, but just like the Jameco part, there may be height clearance problems.
It is to late today, but tomorrow I will try and get photos to show the situation that I am dealing with on this battery drawer
Old 09-24-2017, 09:27 PM   #14
Ecodog's Avatar
2007 25' Safari FB SE
Sonoma , California
Hi there Wayne,
Shorter wire runs and loss free connections are positive steps to improving your inverter performance, but are you measuring a significant voltage drop across the 300A breaker that would justify replacing it?
DG
Gibson
Ecodog is offline   Reply With Quote
Need a pair of 1989 Excella 1000 34ft USED segment protectors. ASTailgate Rock Guards, Segment & Window Protectors 2 08-07-2017 10:49 PM
Need a pair of zip Dee tire skirts for two axle Scout1457 Airstream Classifieds 1 10-28-2015 04:05 PM
Pair of Hondas for Home Stand-by Cracker Generators & Solar Power 11 02-23-2006 06:01 PM
