Also the purple, pink, and yellow wires are all the same gauge, so it would follow that they should probably all have the same fuse rating. If someone went from a 20 to a 30 amp fuse because the fuse kept blowing, that's how electrical fires happen.
Finally, why is brown on the neutral bus? On my Overlander, brown is connected to the positive bus through a fuse, same as the other colored wires. Do you happen to have a section of
12V plugs/lights in your trailer that aren't working? That might be why.
