Old 09-15-2007, 08:32 AM   #15
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Uwe - what are the advantages of the round vs. flat. Does it stay connected better?
Old 09-15-2007, 08:49 AM   #16
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Yes, and it is a very positive connection. I often had to wiggle the plug when I was using the 7-flat, and clean out corrosion.
But the real reason is that the round pin connectors carry twice the current over the flat pins. 20A rating for the flat pin, 40A for the round pin. Providing that you have a 10g or better charge wire, this can really make a difference in battery charging, and also safely provide a more stable current to the trailer without fear of overloading the trailer connector. This is especially important for 12V refrigerator users, or in my case, trailers with electro/hydraulic brakes.
I have attached a .pdf with trailer connectors.
Uwe
www.area63productions.com
Old 09-15-2007, 09:14 AM   #17
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Or you could use a 9 pin, that's what come with my 86 excella. then you can sister up a few of the round pins, provide enough current to set off some sort of nuclear devise, or have the right turns going left, bachups forward, brakes stopping on go and going on stop.reefer heatin,heater freezin. just give me a flat 5. lol
how's the new rig newguy? Burbmen rule.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 09-15-2007, 10:30 AM   #18
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Nuclear device....not a bad idea. Nuclear reactor for boondocking power, downsized to fit into the bumper compartment.
The new Suburban is doing great, so far. Drives nice.
Uwe
Old 10-03-2007, 01:13 PM   #19
1976 27' Overlander
Stuarts Draft , Virginia
Here you go. I just went down this road last week. See where I changed the colors on the wires coming from the camper to the Tow vehicle. On the flat 7 pin RV change the black to the blue. The yellow to black and the blue to yellow. The color code from the AS for the electric brakes , backup lights and power does not line up to the color code of the RV 7 pin flat. The brake lights, ground, left and right signals do line up with the right color codes. Good luck.
ID:	46491   Click image for larger version
mountainman1 is offline   Reply With Quote
Old 10-03-2007, 01:19 PM   #20
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Thank you!
Uwe
Old 10-03-2007, 01:48 PM   #21
1976 27' Overlander
Glad to help. I lost some sleep on this one.
Wiring Diagram? griffinia Electrical - Systems, Generators, Batteries & Solar 6 01-21-2007 08:05 AM
Anyone have a Wiring Diagram? Chopper Electrical - Systems, Generators, Batteries & Solar 14 09-22-2006 09:49 AM
Wiring Diagram please Drifter Electrical - Systems, Generators, Batteries & Solar 1 06-04-2004 06:21 PM
wiring diagram frederic.c01 Electrical - Systems, Generators, Batteries & Solar 1 05-30-2004 01:59 AM
wiring diagram? nu2argosy Electrical - Systems, Generators, Batteries & Solar 2 04-20-2004 07:30 PM
