Old 09-28-2016, 05:28 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Necessary to upgrade Parallax 8355 on 2017 International?
I'm wondering if it is necessary to upgrade the 8355 Parallax Converter/Charger in my 2017 Airstream in order to protect the batteries when plugged in to shore power.
I upgraded the Parallax on my 2014 International in order to have multi-stage performance to help preserve the 6Volt AGM batteries.
Parallax touts their TempAssure battery protection feature in the 8300 series but don't talk about a "multi-stage" feature.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-28-2016, 05:41 PM   #2
New Borockton , Alabama
Images: 21
We've tried it and even sent one to Lifeline for testing when they first came out a few years ago in the deck mount configuration. Bottom line, they don't really get the batteries fully charged and certainly not in a timely matter. I think the 4655 with remote is a better option for the 8355.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 09-28-2016, 06:09 PM   #3
Was it the 8355 that you tested?
What is the 4655 and does it replace the 8355?
Old 09-28-2016, 06:43 PM   #4
Images: 21
It was not the 8355 but it was a Parallax unit with the same TempAssure. They all use the same charge profile.
The PD 4600 series is a 4 stage Progressive Dynamics Inteli-Power upgrade for all Magnetek and Parallax 6300/7300/8300 series units. In your case you have a 55 amp model so you would need a 4655.
Old 09-28-2016, 06:46 PM   #5
Great. Thanks Randy.
Old 09-28-2016, 06:54 PM   #6
1981 31' Excella II
New Market , Alabama
This did it for me.
Perry
Old 09-28-2016, 07:00 PM   #7
Originally Posted by perryg114 View Post
Not being very electrical savvy.......question.....how does the the 4 stage Progressive Dynamics PD 4600 functionally compare to the 3 stage Powermax Pm3-55?
Old 09-28-2016, 07:07 PM   #8
1981 31' Excella II
I expect it is a matter of semantics. As long as the lowest level is such that the battery is not being over charged then I don't see the difference. At some point, stages are not relevant. Without real test data there is no way to tell. There probably is no real data to compare the two and which one gives you better battery life. Probably the ones that measure battery temperature and regulate charging based on that are going to be the absolute best but even the 3 stage is better than my 35 yr old converter that was putting out mainly AC.
Perry
Old 09-28-2016, 09:29 PM   #9
Images: 21
First, the PM3 is being discontinued for RV service. Jayco might be the last OEM using them and not an any of their higher end units I'm aware of. We don't even fool with them anymore. When they came out the fan control was on the DC side so it would slowly discharge the batteries when not plugged into shore power. Not good.
With the Boondocker and Progressive Dynamics units, the fan control is always on the AC side and the boost voltage is higher and longer for full battery charging and subsequent maintenance. With the PD units, you also have control of the charge mode and status monitoring.
The 4th stage is called the desulfation or equalization stage but the former is more correct. It periodically raises the voltage to the max boost voltage for about 15 minutes to mix up the electrolyte and prevent stratification that leads to sulfation and premature battery failure. Does not affect AGM batteries in any way so that is not an issue when compared to deliberate equalization that some of the higher end inverter/chargers are capable of.
We've tested every single unit that has hit the market since 1999 and most made since the 60s and have a little to base our opinion on but by no means have all the answers.
Don't be afraid to ask questions being non electrical savvy. That's how we all keep learning
Old 09-29-2016, 12:12 PM   #10
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
After acquiring our 2016 27, I replaced its Type 24 lead-acid batteries with Type 27 AGM batteries, and, at Randy's recommendation, replaced its stock converter with a 4655. The installation went flawlessly, thanks to Randy's installation instructions & videos, and the AGM/4655 combination has worked flawlessly so far, simply "No problems." Thanks, Randy.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 09-29-2016, 06:50 PM   #11
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
Great piece of information, Randy! I learned something new today!
Ronman is offline   Reply With Quote
Old 09-29-2016, 07:50 PM   #12
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Can anybody tell em what a "Charge Wizard" is and what it does??
MelGoddard is offline   Reply With Quote
Old 09-29-2016, 08:10 PM   #13
2014 23' FB Flying Cloud
Park City , Utah
Best Converter Installation Videos
I looked on Randy's site and couldn't find videos and couldn't come up with anythying on Youtube. Can you direct me to video instructions for upgrading to a PD4655, I'm buying a new to me 2014 FC 23 and will be ordering one of these from Randy for sure. Would like some due diligence on how to swap it out in advance so I can study up!
pcskier is offline   Reply With Quote
Old 09-29-2016, 08:54 PM   #14
Images: 21
http://http://progressivedyn.com/charge_wizard.html
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 12:46 PM
Parallax 8355 Converter/Charger (lower unit) Candominium Airstream Classifieds 0 08-10-2016 06:46 PM
Parallax 8355 - Keeper, Junk, or Something Else? StillRod Electrical - Systems, Generators, Batteries & Solar 40 04-12-2015 07:22 PM
Parallax 7300 convertor upgrade problem JackRenner Electrical - Systems, Generators, Batteries & Solar 13 10-02-2012 05:27 AM
