Old 09-29-2016, 10:45 PM   #15
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
For installation instructions & videos for installing a 8955 converter, go to:
http://www.bestconverter.com/Magnete...Kits_c_64.html
and click on Installation Photos
In my prior note, I said I had installed a 4655; in fact, it was a 8955.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 09-30-2016, 08:12 AM   #16
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by 68 Overlander View Post
Very interesting. Thanx😊
MelGoddard is offline   Reply With Quote
Old 09-30-2016, 08:28 AM   #17
2014 27' Flying Cloud
Elizabethtown , Kentucky
Originally Posted by pcskier View Post
I looked on Randy's site and couldn't find videos and couldn't come up with anythying on Youtube. Can you direct me to video instructions for upgrading to a PD4655, I'm buying a new to me 2014 FC 23 and will be ordering one of these from Randy for sure. Would like some due diligence on how to swap it out in advance so I can study up!
I also have a 2014 FC, completed the Converter upgrade w/the PD4655 series
unit after over charging the batteries which were probably shot before I even
bought the unit, as I purchased in 2015, & I keep the A.S. plunged to shore
power all the time as I have never used the A.S. EXCEPT to run a heater in the
winter or a fan in the summer to keep air moving & moisture down, carport
kept. Plans changed, so it sits under cover of the carport. Nice to walk in the
unit, flip the light switch, have a seat, etc, etc. The Converter upgrade is the
best money you can spend. What is your peace of mind worth to you?
BestConverter.com.
My A.S is for sale as it needs to be used as intended. As I stated, plans change.
Never used, never connected to water, tags still hang where they were placed
from factory, 2 replaced batteries, Converter upgrade, carport kept.
Never slept in, nothing used except lights. GREAT unit 270-765-6620
2014 Airstream Flying Cloud 27FB
$52,500.00, Michael
hensley2015 is offline   Reply With Quote
Old 09-30-2016, 01:41 PM   #18
New Borockton , Alabama
Images: 21
The photos are of the 8955 but the procedure is almost identical for the PD4655.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
Old 10-04-2016, 09:08 PM   #19
Originally Posted by interstateflyer View Post
I'm wondering if it is necessary to upgrade the 8355 Parallax Converter/Charger in my 2017 Airstream in order to protect the batteries when plugged in to shore power.
I upgraded the Parallax on my 2014 International in order to have multi-stage performance to help preserve the 6Volt AGM batteries.
Parallax touts their TempAssure battery protection feature in the 8300 series but don't talk about a "multi-stage" feature.
I asked Andy at CanAm about swapping the converter and he said not to bother.
The converter on my FC (Parallax 7300) is putting out 13.3 volts which will not overcharge the battery.
My manual says to leave the switch in use when AC is on,
Presumeddly to absorb any voltage spikes.
In storage I have a timer.set for two hours a day to keep the batteries up.
Old 10-04-2016, 09:32 PM   #20
Images: 21
13.3 is never going to fully charge your batteries even if your Airstream meter shows full.
Parallax target voltage is 13.8 so I would confirm your readings. If accurate, its not high enough. If its actually 13.8, monitor them closely.
Andy is a good guy.
Old 10-05-2016, 06:51 PM   #21
Andy is a good guy.
Thanx. I'm going from memory, so I'll check it again.l
Old 10-06-2016, 05:42 PM   #22
[QUOTE=68 Overlander;1860409]13.3 is never going to fully charge your batteries even if your Airstream meter shows full.
Andy is a good guy.[/QUOTE
Checked it today with AC on,
After two hours, the readout showed 13.6. and stayed there.
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 12:46 PM
Parallax 8355 Converter/Charger (lower unit) Candominium Airstream Classifieds 0 08-10-2016 06:46 PM
Parallax 8355 - Keeper, Junk, or Something Else? StillRod Electrical - Systems, Generators, Batteries & Solar 40 04-12-2015 07:22 PM
Parallax 7300 convertor upgrade problem JackRenner Electrical - Systems, Generators, Batteries & Solar 13 10-02-2012 05:27 AM
