Old 10-03-2009, 03:03 PM   #1
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Mystery Receptacle
I have a 1960 Tradewind that I'm "renovating". It has 2 different receptacle / umbilical cord connection points, they both look like they were factory installed originals. The bigger one looks like the typical point of connection, I have the cord that matches it AND I have verified that it works.
I'm trying to figure out what the other one is for and if I should keep it for some reason. It is about 3/4" in diameter and has 4 prongs. The wires connected to it are fairly heavy gage. 2 wires are tied together and then go into the wall above, 1 wire goes with that wire into the wall above and then the 4th wire goes to the break away switch.
Thanks for your help, MarkR
ID:	88142   Click image for larger version
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-03-2009, 03:11 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I believe this is where you would plug in the battery. Do you have 12VDC power in the trailer?
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-03-2009, 03:21 PM   #3
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Lee, I do have 12v, I have (had) reduntant lights at each fixture location (a 12v and a 110v).
I'm replacing "everything", including installing a converter (which this trailer didn't have, not sure when they started using them). I'm also moving the battery location. Regardless, I'm thinking there would no longer be a reason to have this kind of connection point - true?
Thanks, MarkR
Old 10-03-2009, 03:27 PM   #4
1967 22' Safari
1960 Caravel
Images: 8
If it's what I think it is then there would be no reason to have that anymore. I moved the battery plus converter inside and wired 12vdc thoughout the 60 Caravel. It originally had only one 12vdc light. Now I can boondock.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-03-2009, 03:27 PM   #5
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
12vdc connection
the previous owner may have carried extra battery power in his/her tow vehicle, and connected them to the trailer via this connection-just extra reserve power. Not a bad idea, overall-but one would need the matching plug/receptacle to connect.
wmarsha is offline   Reply With Quote
Old 10-03-2009, 03:48 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That plug is for a separate 12 volt battery, two prongs positive, two negative.
1964 was the first year for a dedicated converter, AKA Univolt.
Old 10-03-2009, 06:03 PM   #7
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Thanks for all the info!
MarkR
12V Receptacle henw Batteries, Univolts, Converters & Inverters 16 11-29-2017 09:02 AM
Wiring 30 amp receptacle BlueBelle Electrical - Systems, Generators, Batteries & Solar 9 11-03-2015 11:49 AM
12 volt receptacle tlavergne Audio, Video & TV 3 07-02-2008 09:13 PM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
Antenna/TV receptacle Al1 All Argosy Trailers 11 07-06-2004 12:20 PM
