Old 08-02-2007, 12:12 PM   #15
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet The Cat's Been Here
Originally Posted by Excella CM
Every trailer has a tongue, unless, of course, the cat got it. (I know, I know, I should mind my own!)
This is a note card from a coworker, an aspiring Airstreamer. Couldn't resist.
Vaughan
Name:	No Toung.jpg
Old 09-09-2007, 10:38 AM   #16
1974 Argosy 20
Burlington , Ontario
In favour of the univolt.
It is really just a 6 volt power transformer with a voltage doubler circuit and a blockig diode to prevent current flowe back to the car.
If the voltage is down then the cause is to replace the doubler capacitor. A 1 ufd 20 volt capacitor obtainable from any electric motor shop for just a few dollars. The diodes are10 to 20 amp and are also available. the tansformer will not reduce the output.
Rae
ve3czn is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
mystery battery drain FOUND Curtis-79MH Airstream Motorhome Forums 1 06-18-2003 09:03 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
12 VDC Mystery roessler Electrical - Systems, Generators, Batteries & Solar 3 08-01-2002 05:20 PM
