Old 03-13-2010, 03:47 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
My Xantrex Freedom 10 Inverter-Charger Installation
This was the first time I installed an Inverter-Charger combination unit in an RV. If you're not familiar with this kind of Inverter-Charger, it provides AC to all of the regular 110v outlets in your trailer. I wanted this unit to run my TV, DVD player, DIRECTV Satellite Receiver, and my wife's curling iron. This 1000 watt unit provides plenty of juice for my needs.
With limited experience with 110v AC and having never installed one of these before, I was a bit intimidated at first, but after consulting with our resident expert "Lewster," it was a pretty simple job actually.
The installation manual calls for a separate breaker box for the Inverter output which is wired to the 110v circuit(s) you choose. I used a 15amp breaker to protect this circuit. The AC input to the inverter is provided by the main breaker box which also houses the air conditioner circuit. The inverter ground was wired directly to the ground bus in the main fuse box.
For the DC side, the installation manual called for 2 gauge wire but I decided to go larger with 2/0 to minimize loss as much as possible. These wires are very large and very difficult to manuever and bend. The biggest problem I encountered with this project was the lack of space on the + battery post. Including the Link 1000 battery monitor leads and the Inverter temperature sensor, I needed to connect six leads to the post but didn't have enough room, so I had to make my own aluminum bus. I added an additional two posts to this homemade bus which gave me plenty of room for all of these connections.
I'm using the Link 1000 to remotely control the Freedom 10 Inverter-Charger.
I took these pics of the installation after watching an episode of the Rockford Files on Inverter power. Worked great. I was also surprised at how efficient the Charger unit was. I had never before gotten 14.2 volts during charging with my old Magnetek, but I did with this Xantrex unit. I'm very pleased with this unit.
Top pic shows the Freedom 10 installation under the streetside twin bed. Pic 2 shows the new breaker box for the Inverter circuit (all 110v AC outlets are wired to this). Pic 3 shows my battery box with the associated 12v wiring. Pic 4 shows the homemade 12v bus bar for the + lead.
ID:	98032   Click image for larger version
ID:	98034   Click image for larger version
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-22-2010, 02:16 PM   #2
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
Nice setup!
How did you sort out securing the batteries while maintaining the integrity of the battery box?
How well does your aluminum buss bar conduct?
Cheers
ostream is offline   Reply With Quote
Old 03-22-2010, 03:04 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by ostream View Post
Nice setup!
Cheers
Thanks for the compliment.
The batteries are quite secure in the battery box. The box is made of a very durable, thick plastic and vents outside via the white plastic hose seen in the picture.
The bus bar conducts extremely well and works even better than I had imagined.
1958 Overlander
4CU 1st VP
New Xantrex Converter/Charger 68 Overlander Commercial Listings 6 07-25-2012 07:01 PM
installing a Xantrex inverter? boondockdad Batteries, Univolts, Converters & Inverters 12 12-05-2007 12:25 PM
Inverter / Charger Newbie nbk3ad2 Electrical - Systems, Generators, Batteries & Solar 22 02-02-2007 09:23 AM
Inverter/Charger LRPorter Electrical - Systems, Generators, Batteries & Solar 10 02-18-2006 11:05 AM
Inverter/charger option mcneon Airstream Motorhome Forums 0 03-24-2004 05:37 PM
