Old 06-08-2015, 05:40 AM   #1
My invertor suddenly stopped!
Hi, I am restoring a 75 trade wind and nearing completion. I wired some new lights in, 12 volt led. I connected them to the same wires that used to operate the small pocket lights located in the over head panel over the front couch. when I reconnected the electric, I have no power to these 3 new lights, and my invertor suddenly stopped. Could I have fried it? Any and all help is greatly appreciated. Thanks, Ray
nu2argosy is offline   Reply With Quote
Old 06-08-2015, 08:11 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you checked the fuses?
You don't have an inverter. You have a converter.
If it is the original. There are fuses inside the small door on the end or near by.
Old 06-08-2015, 09:43 AM   #3
richinny's Avatar
2011 34' Classic
i think led light might be polarity sensitive. that is it matters if the positive is connected to the positive and not reversed. test for power at the connection with a meter or test light.
Ricky
Old 06-08-2015, 09:47 AM   #4
Thank you for your help, and yes convertor,thanks.Are these fuses inside the convertor?Do I have to remove the rivets, as I tried to remove the nuts on the other end but cannot figure out how to open it. When plugged in ,I do hear a very low hum, not as usual. Thanks, Ray
Old 06-08-2015, 10:22 AM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If you have the original UniVolt, I have an easy answer for you - replace it. There are much, much better converter/chargers out now. The new ones charge your battery better, weigh less, and put out considerably less heat.
Old 06-08-2015, 11:16 AM   #6
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
As said above, LEDs are polarity sensitive. They will not work id wired wrong. The power they use is near zero when they work and zero for sure when they don't so I can't see how you could have fried anything. Reverse the wires and try again.
Gearheart is offline   Reply With Quote
Old 06-08-2015, 01:06 PM   #7
Thanks again all for your great help. Still looking for fuses, though I am consisdering buying a new one, for sure.
Old 06-08-2015, 02:00 PM   #8
1979 23' Safari
Wayland , New York
If the fuses as part of the univolt are used, and you replace it, keep in mind that you'll have to rewrite those lines to a new fuse panel. If you've got the blue box around the univolt, the fuses may be in a panel in the wall above it.
Some, not all LED lights are polarity sensitive, some have circuits built in to negate this, but one that is polarity sensitive in backwards blocks current in that line if connected serially.
Old 06-11-2015, 03:50 PM   #9
richinny's Avatar
2011 34' Classic
nu2argosy, try contacting LEDs 4, Recreational Vehicles for info about the wiring of the leds. dan is a member of the forum and can help you out with lighting questions.
Ricky
Frig 110 Volt running on invertor on the road? airdreamers Electrical - Systems, Generators, Batteries & Solar 8 07-03-2014 06:46 AM
Toilet Suddenly Stopped Working txairdream Sinks, Showers & Toilets 22 06-26-2014 09:54 PM
Suddenly the shower stopped working deepsea Sinks, Showers & Toilets 7 01-05-2010 09:00 AM
Water flow stopped suddenly dryan Plumbing - Systems & Fixtures 7 08-25-2008 06:25 AM
Refrigerator on Invertor moosetags Refrigerators 21 04-30-2007 06:35 PM
