Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 12-23-2007, 12:26 PM   #1
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
My Converter stopped converting
I finally made it to Florida!
My batteries were a little low 75% or so.
I hooked up my trailer to 110 last night and looked at my solar panel readout. It stayed at 75%. Well I had enough to get me through the night.
All the rest of my 110 works. I checked the outlet under the couch that feeds the converter. 115VAC. I checked the pair of 30A fuses. Fine. I checked the buss where the converter is tied in. 12.3VDC. Bummer. It quit.
I looked around for breaker on the converter. Nothing.
So is ther anything to check or do I need to make an appointment at JD Sanders in Alachua?
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 12-23-2007, 03:04 PM   #2
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
I'm not familiar with your converter but it sounds like you have a problem. If you need to live in your trailer until you can get an appointment you're going to run your batteries down beyond the point where they could be damaged.
When I was in the same situation, I bought a battery charger and used it a few hours per day until I could replace my converter.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 12-23-2007, 03:13 PM   #3
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Was the 12.3 VDC open circuit or were the batteries still in the circuit? Try the reading open circuit to be sure it is not a bad battery.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 12-23-2007, 05:01 PM   #4
thecatsandi
Missoula , Montana
the 12.3 was the converter connected and the batteries connected. I unplugged the converter and hooked up a battery charger. The battery voltage is slowly coming up. I am up to 12.5 now.
Michelle
Sarah
Old 12-23-2007, 06:01 PM   #5
DreamWeaver
Profile:  1976 31' Sovereign
St Petersburg , Florida
I've been following your travels for the last few weeks. You are quite an airstreamer!
Bates RV is just off I75 and I4.
I'm in St Petersburg just north of Skyway Bridge (30 min or so from Bates).
If you need a place to stop for a night or two we may have a spot available at our shop in Pinellas Park.
Let me know if I can help.
Steve
DreamWeaver is offline   Reply With Quote
Old 12-23-2007, 06:29 PM   #6
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
michelle,
pop the cover off, i am pretty sure there is a fuse inside if yours is like mine.
worth a try before you go to the dealer.
john
you call them ferrets, i call them weasels.
Old 12-23-2007, 07:10 PM   #7
HowieE
HowieE's Avatar
Images: 11
Disconnect the groung leg at the converter and check the battery voltage again. Even if the fuse in the converter has blown your charge is still seeing the converter while charging the batteries and if the problem is in the converter it may be a load on the charger.
Old 12-24-2007, 06:38 AM   #8
thecatsandi
Missoula , Montana
I am not inclined to go inside the unit quite yet. She is still under warrenty.
Michelle
Sarah
Old 12-24-2007, 06:50 AM   #9
thecatsandi
Missoula , Montana
Howie,
I will try that this afternoon. I am having my truck 30,000 mile service this morning. I though about that but I should be getting 13.8 unless a cell is shorted. Then I would have expected a fuse to blow.
Michelle
Sarah
Old 12-24-2007, 09:34 AM   #10
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
I think I remember you had an open fuse that prevented the TV from maintaining your AS's battery so am wondering has that opened again since you've spent enough time driving you should be seeing 90+% state-of-charge?
I don't know enough about new Airstreams to point in any one direction but checking the primary frame ground for corrosion or high-capacitance connection (voltage but no current flow) would be a worthy thing to accomplish - having a semi floating ground would allow switching noise and spikes etc. to romp in all the electronics...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 12-24-2007, 10:55 AM   #11
HowieE
HowieE's Avatar
Images: 11
Yes, and with that in mind disconnect the TV from the trailer and read the charging voltage on the truck batteries while you are testing things. Lets make sure things are good at that end. Just after a cold start the alternator is up to snuff.
Old 12-24-2007, 05:42 PM   #12
thecatsandi
Missoula , Montana
THat is a possiblity I bought a plug checker thingy. I do run with the lights on especially on Saturday when it was overcast and raining off and on. There may not have been much left to charge the trailer. I seem to remember the truck buss voltage running around 13.5
I should not be having grounding problems yet! The trailer is less than 2 years old. THe converter is defiantely bonkers. I have an appointment at Sanders to have them replace the converter just prior to the Can opener.
Michelle
Sarah
Old 12-24-2007, 05:45 PM   #13
thecatsandi
Missoula , Montana
Strangely enough the buss voltage creeps up to 14.1 in about 30 seconds. It takes a little time to bulk charge the batteries after a start.
Michelle
Sarah
Old 12-24-2007, 07:27 PM   #14
HowieE
HowieE's Avatar
Images: 11
Sounds like the truck is OK. How about plugging the trailer back into the truck and do the test on the truck again. With the amount of towing you have been doing the trailer batteries should have a near full charge when you first park for the night. If after this second test you don't see 14 volts there is something in the trailer that is drawing things down.
How do you clear a stopped up black water tank? Aluminumb Waste Systems, Tanks & Totes 9 10-26-2007 12:11 PM
Converting 64 Globetrotter to Caravanner everyman 1964 Globetrotter 2 04-26-2007 07:44 PM
Converting to Bubble PoconoAir 1955 Flying Cloud 27 02-05-2007 08:37 PM
The furnace stopped working ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-24-2006 02:04 PM
Tail Lights Stopped Working dpope 2003 Safari 8 04-05-2003 12:22 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum -
