Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 12-25-2007, 09:28 PM   #15
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
I should not be having grounding problems yet! The trailer is less than 2 years old.
(humor mode on)
Of course not. Especially with it being located on the ladder frame rail where the belly skins might allow persistent humidity to invade when its been driven through weather or salted roads, certainly it couldn't have turned green yet, even if the last tech to touch it had other things on their mind...
Yes Ma'am, I apologize... A well lived in trailer may well have the converter going bonkers all on its own, I've just seen too many bad wires in my time - one engineering mod had me QA on a good share of 27000 HV wire re-terminations. All that aside - here's wishing you the best for the New Years!
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 01-03-2008, 09:41 AM   #16
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
They replaced the converter yesterday. I asked the tech and he said it was definately dead. I already knew that but I wanted to hear it from him.
My next problem A black tank leak when she is full.
I found that out when I stopped at JD Sanders and the inside smelled really bad. Then I stopped for fuel and brown stuff was running on the ground.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 01-03-2008, 10:05 AM   #17
jkcru
jkcru's Avatar
Profile:  1976 23' Safari
Escondido , California
It Never Ends!
jkcru is offline   Reply With Quote
How do you clear a stopped up black water tank? Aluminumb Waste Systems, Tanks & Totes 9 10-26-2007 12:11 PM
Converting 64 Globetrotter to Caravanner everyman 1964 Globetrotter 2 04-26-2007 07:44 PM
Converting to Bubble PoconoAir 1955 Flying Cloud 27 02-05-2007 08:37 PM
The furnace stopped working ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-24-2006 02:04 PM
Tail Lights Stopped Working dpope 2003 Safari 8 04-05-2003 12:22 PM
