Old 05-18-2014, 07:21 AM   #1
2003 28' Classic
Ladysmith , Wisconsin
My converter and batteries
Just wanted to post a picture of the converter and batteries in our 03 28' Classic. The batteries were purchased in 2010 and the converter a 4 Stage I believe was factory installed. Click image for larger version
Name:	ImageUploadedByAirstream Forums1400419247.218591.jpg
ID:	212194Click image for larger version
Name:	ImageUploadedByAirstream Forums1400419270.214123.jpg
JacobMerridy is offline   Reply With Quote
Old 05-18-2014, 07:23 AM   #2
2003 28' Classic
Originally Posted by JacobMerridy View Post
Just wanted to post a picture of the converter and batteries in our 03 28' Classic. The batteries were purchased in 2010 and the converter a 4 Stage I believe was factory installed. Attachment 212194Attachment 212195
Progressive Dynamics' PD9260C recharges your RV’s battery to 90% in 2-3 hours and extends your battery’s life! Most converters with a built-in battery charger only have one charging mode, 13.6 volts. Includes a BUILT-IN Charge Wizard. The 9200 has four charging modes and will maintain your battery for longer life and features reverse battery protection, filtered DC power, electronic current limiting, low line voltage protection, intelligent cooling fan, high voltage protection, automatic thermal shutdown, and variable speed fans. Replaces any floor/bunk mounted converter. 1/box.
Old 05-18-2014, 07:34 AM   #3
2003 28' Classic
The batteries were purchased at Costco
Old 05-18-2014, 07:39 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
PD builds a quality unit, but they are missing a few VERY IMPORTANT features:
temperature compensation. This is the ability of the charging section to change the voltage profile to fit the temperature of the batteries (using a temperature sensor connected to a negative terminal of a battery). For example, Lifeline AGM batteries require a 14.3VDC absorption charger at 77ºF (25ºC) and a float charge of 13.3 VDC. At 100ºF, these numbers change to 14.04/13.02 while at 50ºF, they are 14.72/13.7. It is easy to see that a charger without temperature compensation can either under/over charge your batteries on a regular basis.
adjustable charging time. Depending on the size of your battery bank and the type of batteries, they will need more/less time in absorption phase. Standard converter/chargers do not offer this feature.
battery type. Again, different types of batteries need different charge profiles and there is no adjustment for this on a converter/charger. AGM batteries (at 77ºF) need 14.3/13.3 VDC for absorption and float. Some liquid lead acid batteries need up to 14.8/13.6 VDC. It all depends on the battery construction and the manufacturer's specifications.
The only units that DO offer all of this is a quality inverter/charger.
Old 05-18-2014, 10:20 PM   #5
2003 28' Classic
The Costco batteries are $90 and it they last 5 years, I'll be happy and keep this average converter.
Mixed batteries and surprised with converter/inverter outofcontrol Batteries, Univolts, Converters & Inverters 14 05-08-2014 09:04 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
factory supplied converter and batteries rayandre Batteries, Univolts, Converters & Inverters 9 02-23-2011 05:47 AM
New converter and batteries flsafari Electrical - Systems, Generators, Batteries & Solar 19 04-30-2006 04:04 PM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
