Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 07-08-2008, 08:24 AM   #1
vhord
vhord's Avatar
Profile:  1970 27' Overlander
Crosby , Texas
Images: 95
My 12V lights were pulsing
This past weekend while camping my LP detector started beeping and at the same time the interior lights started pulsing (dim to bright, dim to bright). I turned off the A/C and it stopped. The A/C did not seem to be laboring. I turned the A/C back on and everything was fine. It did this twice over a four day span. The first time it stopped on its own without turning off the air.
Any ideas? Voltage drop from my shore power, converter, bad LP detector, or what?
BTW - I was camping in my temporary Airstream (2004 Starcraft pop-up camper) in a RV park and I was connected to 30 amp shore power with no extension cords or adapters.
Vernon
1970 27' Overlander Restoration ("The Silver Belly", aka The SB)
Photo gallery
AIR #26858
vhord is online now   Reply With Quote
Old 07-08-2008, 10:41 AM   #2
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I have had this and it was a week converter cycling on and off.
Keep a voltmeter handy and if it happens again read a 12 volt line while in eack of the 2 conditions. I suspect you will see it dropping.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-08-2008, 11:32 PM   #3
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Agree, keep a voltage meter with you or even a simple plug-in that you can look at and read the actual voltage. Closer to the source the better. Read right off the output lugs on the converter if you can.
Old 07-09-2008, 12:53 PM   #4
vhord
vhord's Avatar
Crosby , Texas
Images: 95
BTW - while it was doing this I checked my battery indicator and it read fully charged. Seems the battery alone should have operated the lights and LP alarm or should it?
Vernon
Photo gallery
AIR #26858
Old 07-09-2008, 01:25 PM   #5
HowieE
HowieE's Avatar
Images: 11
The battery indicator is not accurate enough to rely on for this evaluation. The battery is fully charge or close to it but the converter is cycling on and off suppling additional voltage when it comes on. It is this increase voltage that you see as a flash.
Furnace / Pulsing Red Light / Code ? B4WEDI Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-21-2007 01:55 PM
New lights and the 12V issue soldiermedic Electrical - Systems, Generators, Batteries & Solar 8 10-30-2006 06:33 PM
12v reading lights '65. popped out ronmcor Electrical - Systems, Generators, Batteries & Solar 4 11-29-2004 07:07 PM
lights 12v and 110 v moe146 Electrical - Systems, Generators, Batteries & Solar 5 05-16-2004 06:37 AM
Some 12v lights don't work bjstewart1 Electrical - Systems, Generators, Batteries & Solar 6 07-22-2003 05:42 AM
