Old 06-06-2009, 08:48 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Moving the batteries up front.
Ok, I would like to take the batteries out of the back on the trailer and put them up on the tongue. With two of them right in the back it seems like unnecessary weight on the rear end.
My question is will There be enough power if I run the wires from the front to the back to the inverter. I figure on using 10 or 8 gage wire.????
Then, do they make a box to cover 2 batteries long end to long end???
Or will I have to make one of those too. Could look nice out of aluminum!!!
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-06-2009, 09:06 PM   #2
I wouls suggest that you use # 6 wire, with a 50 amp 12 volt circuit breaker in the line.
The battery box, you will have to make, or make a platform, and strap on a couple of plastic battery boxes. The only problem with the plastic battery boxes, is that everyone can see them, and the batteries might mysteriously disappear, when your not looking.
But, I sure you know that no one would steal them, but they might borrow them, permanently.
If you make a metal box, make sure you put a couple of small drain holes in the bottom, and a tiny vent at the back of the box, near the top.
Old 06-06-2009, 09:26 PM   #3
purman's Avatar
1968 28' Ambassador
Why the Circuit breaker Andy?
I would like to move the inverter to but I would still have to run the wires from that to the back as well, and there is really no place for it up front. So I figure just the battery lines is enough.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-06-2009, 09:55 PM   #4
A 12 volt circuit breaker, is an electric safety device in your case.
If anything went wrong, with the wiring, caused by who knows what, vibration, accident, or what ever, you have protected the entire trailer from a possible fire.
Cheap insurance, to say the least.
Old 06-06-2009, 11:05 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I'd like to put two batteries on the tongue of my '72, too, but I don't thing there is enough room.
Purman, is there enough room on the tongue of your '68 to do this?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-07-2009, 08:26 AM   #6
purman's Avatar
1968 28' Ambassador
I have two of the regular size batteries, If I put them long end to long end they just fit in front of the lp tanks and the jack stand. I have made a bracket to hold them out of angle iron that I was using in the rear.
There is about 3/4 of an inch on either side of this to spare. I will be making an aluminum cover with a vent on the back side to cover them.
I thought I would have to move the brake away switch but it just clears it.
Now, if I put the batteries side by side short ways, they would not fit.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Moving front door to back newroswell Doors & Locks 4 03-28-2009 10:44 AM
Moving batteries and/or Univolt linjoe21 Batteries, Univolts, Converters & Inverters 0 05-29-2006 07:00 PM
Moving the batteries dmadam Electrical - Systems, Generators, Batteries & Solar 8 03-06-2006 01:28 PM
Moving front lounge to roadside darryl97420 All Argosy Trailers 4 10-08-2005 10:54 AM
Moving the camper without the front jack wheel Silvertwinkie Our Community 9 07-22-2003 06:46 PM
