Old 05-21-2013, 06:49 AM   #1
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Moving the Batteries
In restoring my 1978 31' Sovereign, can I move the batteries? Maybe to the outside like this photo? Are there any potential problems to this? It seems like it makes much more sense. Am I missing something?
GAStreamin is offline   Reply With Quote
Old 05-21-2013, 11:13 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If you use big enough wires, you can pretty much put the batteries anyplace you want. Size the battery wires based on the output of your converter (45 watt, 60 watt, etc.). If in doubt, larger wire size is better.
We had originally thought about putting the batteries on the tongue of our '72, but there isn't really enough room on the tongue for two batteries and two 30 lb propane tanks, so we moved the batteries inside, centered in the front inside a battery box under a table.
Chris
Old 05-21-2013, 12:25 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Chris
I hope you vented the battery box, since it is inside.
Dan
Old 05-21-2013, 12:32 PM   #4
GAStreamin's Avatar
Moultrie , Georgia
Chris
I am wondering if there will be enough room too. I am looking at and it appears like there will be, but nothing like measuring exactly. I will have to measure one of these type boxes. Thanks!!!
Old 05-21-2013, 02:25 PM   #5
1974 Argosy 20
Kooskia , Idaho
The new Airstreams (at least the smaller ones) put the batteries in a box in the exact location you show, at the rear of the front tongue. They are located in a metal box a bit lower, with the top of the box about even with the top of the frame.
Old 05-22-2013, 06:17 AM   #6
Minno's Avatar
1972 31' Sovereign
Originally Posted by TouringDan View Post
Chris
Dan
Absolutely.
Old 05-22-2013, 06:37 AM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I got rid of the leaky battery boxes and put them outside on our 94 model trailer. There was only enough room for two group 27 batteries. It is a metal box fabricated by welder. I welded in two struts and bolted the box in place. I borrowed the idea from a newer Airstream trailer.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-22-2013, 06:46 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I make battery cabling from welding wire cable. It is made to live outside. It is made to be drug around and to be used. It is flexible and user friendly.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-22-2013, 07:00 AM   #9
2003 25' Safari
Riverside , California
Very much like what my 03 Safari came with.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 05-22-2013, 07:11 AM   #10
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Crispyboy!
Thanks for the picture! That's going to be my approach. I removed the battery compartment from the street side of my 76 Safari and placing it same as yours. This seems to be a much cleaner, tighter place. How about heat? I understand that's a battery's enemy. I'm learning a lot about batteries as I am going to add a solar system.
surfpod is offline   Reply With Quote
Old 05-22-2013, 09:19 AM   #11
GAStreamin's Avatar
Moultrie , Georgia
Thumbs up Awesome!!
Wow! This is great! What a helpful picture and explanation. What are dimensions of the box? What metal did you make the box of?
Old 05-22-2013, 09:30 AM   #12
crispyboy's Avatar
1994 30' Excella
I will have to get exact dimensions after work. Only enough room for two group 27 batteries.
WBCCI # 3072
Old 05-22-2013, 10:43 AM   #13
1974 Argosy 20
Kooskia , Idaho
If you make the box, make it tall enough for golf cart batteries. Two of them in series to give you 12 volts will make a much superior battery system than any two 12 volt batteries in parallel. It has been my standard RV battery setup for years.
Old 05-23-2013, 05:40 AM   #14
crispyboy's Avatar
1994 30' Excella
When I initially took my measurements I put my two group 27 batteries side by side to get the three dimensions and also gave them some wiggle room.
The interior dimensions are:
15" x 13 1/2" x 10" high
Steel thickness was 3/32"
I forgot to measure the angle iron but I think it was 1 1/2" angle iron (whatever scrap I had in the garage). One end welded to the cross member and the other to the side of the tongue. The box is bolted in place using three 5/16 bolts.
I drilled a few drain holes in the bottom and some breathing holes near the top. After painting it I coated the inside with some undercoating to help protect from acid spills.
In hind site I should have made the box just a little bigger(taller) for the superior 6 volt batteries but it seemed like it was hanging low enough now and may have have conflicted with the cover for the LP tanks. I didn't want to fiddle with the LP tank cover everytime I inspected the batteries. I would need to add another 1 1/4" in height for the 6 volts. 6 volts are 10 7/8" tall. When these batteries go bad I maybe I will make a change.
Believe me when I tell you that the cover is right up next to the LP tank cover. Sorry this is the only picture I have.
WBCCI # 3072
