Old 05-24-2013, 03:39 PM   #29
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
The door only has 2 slits on top for ventilation and the two built in drains on the bottom. When I constructed the box I have it so that any water will drain out of the bottom holes as seen in the picture below.
The inside of the box is sealed and can handle up to an inch of water if that was to happen. I haven't had the trailer rolling down the highway in the rain yet, but sitting still with the torrential rains we have here in Tampa produced no water in the aluminum box. Not a drop. The frame for the battery door opening is extended to prevent water from running in. Some will obviously blow in but it is the same as was the original. Still, it should be minimal and will still drain right off. It solved my problem of of the busted battery box, and the fact that I wanted more than one battery and my trailer only had the one battery compartment.
Name:	2013-05-24 17.14.01.jpg
ID:	186471   Click image for larger version
Name:	2013-05-24 17.14.27.jpg
Name:	2013-05-24 17.14.22.jpg
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 05-24-2013, 06:25 PM   #30
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
I opted to use this space for my spare tire - Mounting two 330amp golf cart batteries was adding 180 lbs. (90lbs each) to my the tongue weight. I had already removed the front couch and replaced it with two recliner chairs adding about 150 lbs. up front. I put the batteries back over the axles (AGM types) where weight belongs. The spare fits perfectly behind the gas tanks and looks like it was meant to be there (moved the tanks forward about 1 1/2 inches).
Silver Hawk is offline   Reply With Quote
