Old 05-23-2013, 05:46 AM   #15
1981 31' Excella II
New Market , Alabama
Where are your batteries now? Mine are in the front on both sides. I bought replacement plastic boxes for mine and everything seems to be leak free. Pulled the trailer in the rain a few times and no leaks. 30+ years is not bad for a plastic box.
Perry
Old 05-23-2013, 06:14 AM   #16
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
@crispyboy, great pics! Thanks for sharing. Mine are in the front, inside, one on each side not in a box. I would like to mount them outside in a box for access ease and more space inside.
GAStreamin is offline   Reply With Quote
Old 05-23-2013, 06:26 AM   #17
1981 31' Excella II
You mean you don't have an access box from the outside? Like this one, if you don't have these then an outdoor box would be the best.
Perry
Old 05-23-2013, 06:30 AM   #18
GAStreamin's Avatar
Moultrie , Georgia
Perry
Yes, I do have an access door, but it is not in good shape. I put new gasket, but it still doesn't seal well and that is where a good bit of my floor damage was.
Old 05-23-2013, 06:37 AM   #19
1981 31' Excella II
The door is not supposed to seal. There should be a plastic box on the inside. The door is vented and will leak like mad if there is no inner box on the inside. Here is what you need.
Plastic Battery Box for 1977 thru 1981 200276 [200276] - $34.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
When the box is installed properly, you can hose out the interior of the box and no leaks.
Perry
Old 05-23-2013, 06:44 AM   #20
GAStreamin's Avatar
Moultrie , Georgia
Perry
Oh, ok, I understand now. It is nice to see original. Not clear in my manual. What about the other battery? The manual shows another one on the other side, but no door.
Old 05-23-2013, 08:03 AM   #21
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
GAstreamin,
The reason they leak is because the caulk gets old, dried out and the weight of the battery causes flexing where the inner box meets the skin. The boxes are caulked both on the interior and exterior.
Of the 3 trailers I have owned two have had rotten floors due to battery box leaks and the third was stained from leaking. A few more years of leaking and the floor would have been too far gone.
Does your trailer have one or two battery boxes? You can add a second one but you will have to acquire an access door and black battery box. Just realize that it has the potential to leak over time. You would also need to remove the interior skin to install the box to caulk up the inside.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-23-2013, 12:13 PM   #22
1981 31' Excella II
Well nothing wrong with moving them but I thought she should understand how they are supposed to work. The originals are sealed with that white putty stuff that cracks and lets water in. I cleaned all that mess off and used Trempro-635. Not a bad idea to support the bottom of the box with a wedge of wood to help them not crack.
My 30 year old boxes were just starting to come apart. The aftermarket ones seem to be heavier than the originals.
If you remove the door you will have to make some sort of patch to cover the hole. Your trailer may have only had one battery or one may have been taken out. If you remove the center wall section you can see the power buss where the batteries hook in. I only use one battery because I don't boondock. We just need enough juice so the water pump runs and we can pee while traveling if we run across some scary bathrooms.
Perry
Old 05-23-2013, 12:24 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't forget the battery is where power comes from for BRAKES in event of need for emergency brakes on trailer.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 05-24-2013, 05:50 AM   #24
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
My battery box was trashed as well so I just cut it out with my HF multi tool. I then built an aluminum box/frame to rivet to the inside of the original battery box opening and designed it to allow water runoff and ventilation. Caulked it all the way around. Then I built a battery box (as seen in the pix below). Shown without the sealed lid on it of course. Plenty of ventilation. I also made an aluminum screen panel for the inside of the opening to prevent critters from entering. The box will hold up to 3 batteries. Plenty of clearance for taller ones. I also have plastic bins that the batteries sit in. Took about a day to complete.
ID:	186448   Click image for larger version
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 05-24-2013, 06:27 AM   #25
GAStreamin's Avatar
Moultrie , Georgia
I really like all the ideas I have gotten from this thread. Great thread. You all are making it hard to decide which way I fix my battery situation. :-)
Old 05-24-2013, 06:54 AM   #26
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
My decision
Originally Posted by idroba View Post
If you make the box, make it tall enough for golf cart batteries. Two of them in series to give you 12 volts will make a much superior battery system than any two 12 volt batteries in parallel. It has been my standard RV battery setup for years.
This is the route I'm taking. I'm going to be adding solar to be able to be off grid without generator. And for optimal charging, the batteries have to be close to the controller. The closer the better. I'll have 2 6volt golf cart batteries. And very thick welding cable for the cabling.
surfpod is offline   Reply With Quote
Old 05-24-2013, 06:57 AM   #27
GAStreamin's Avatar
Moultrie , Georgia
I would love to have solar, but it won't be this refurbishment go round. Maybe someday down the road.
Old 05-24-2013, 06:58 AM   #28
1981 31' Excella II
How do you keep water from coming in the unsealed door and flooding your wooden box? I am assuming the door is only used as a vent and not to load and unload the batteries?
Perry
