Old 07-22-2016, 07:16 PM   #1
stephenb's Avatar
2011 25' FB Flying Cloud
Hutchinson , Kansas
Moving Battery under Bed 25FB
Hey Airstreamers, I just got back from wildcamping/boondocking in lovely Crested Butte and need some help with electrical.
We had a great time and were off grid for four days. We ran mainly off of my Yamaha ef2000isv2 for a couple hours each day.
I currently have some old worn out Interstate srm's that are crap and want to replace with some lifelines and move them under the bed. I think I'd like two 6 volts. It seems to me that it should be a fairly easy job. I am also replacing the converter/charger with a pd4655v.
I know these things have been addressed elsewhere, but have you tried to search on this forum? It's easier just using google.
Here's my questions
-wiring, I initially with out checking schematics, thought that it would be a direct connect to my converter/charger from my battery under the bed but then wondered if it needed to go to my store/use switch.
-battery size. Has anyone put 6v lifelines under their bed and do they fit? Are they too tall? I know I could and will measure myself but the silver twinkie is in storage and well...I'm lazy and I thought you all would know. Is there a better option? Also has someone made a bracket is one available third party to secure the batteries under the bed.
-lastly i see all these cool trimetic and other brand voltage monitors. Do I really need one? I want to baby these new lifelines I get to get the most mileage out of them. Does the cheap voltage monitor Ive been using that just plugs into the DC acc slot work well enough?
I really appreciate all your comments. I've learned a lot here!
Thanks, Stephen
stephenb is offline   Reply With Quote
Old 07-22-2016, 09:27 PM   #2
Brav's Avatar
2016 25' International
Huntington Beach , California
Here's my questions
Thanks, Stephen
I think you mean battery monitor, not voltage monitor. They do a lot more than monitor voltage - they tell you current state of charge, remaining time, remaining amp hours, amp hours used, temp, etc etc.. if you value your batteries, and even hassle-prevention, get one.
I recommend Victron.
2016 International Sig 25FB
2010 LR RR S/C
Brav is offline   Reply With Quote
Old 07-22-2016, 11:11 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Here's my questions
Thanks, Stephen
You can add a pair of either Lifeline's GPL-4CT or their GPL-6CT golf cart batteries under the 25's bed with no issues. I've done it many times!
Tri-Metrics are fine if you want to see your exact battery condition, along with your DC usage patterns. I would avoid the cheapie as they typically don't show you the true voltage condition of the batteries.
You can easily use strapping to retain the batteries in place. Use either aluminum angle (my choice) or 2 x 2 hardwood strips to form a base around the batteries.
You're on the right track!!
Lew Farber...RVIA Certified Master Tech...ABYC Certified Master Marine Electrician
SOLAR TECH ENERGY SYSTEMS, INC.
AM SOLAR ...MAGNUM…VICTRON ENERGY...LITHIUM & LIFELINE BATTERIESMARINE REFRIGERATION
Old 09-10-2016, 03:53 PM   #4
stephenb's Avatar
Hutchinson , Kansas
Ok. I did it. Took out my OEM Intrastate Batts and put in a couple Lifeliners. GPL-6tc's to be specific. Also upgraded my converser/charger to a pd4655.
Then I got crazy on amsolar's website and got a Vitron 702 Lifeliner monitor. But wait, one more thing. I'm kind of a geeky guy so a got the victron Bluetooth dongle(love saying that word).
Took me awhile to get it all put together cuz I'm not that smart. Here's some pics.
Name:	ImageUploadedByAirstream Forums1473540743.846473.jpg
ID:	271395Click image for larger version
Name:	ImageUploadedByAirstream Forums1473540772.231811.jpg
ID:	271396Click image for larger version
Name:	ImageUploadedByAirstream Forums1473540788.333180.jpg
ID:	271397Click image for larger version
Name:	ImageUploadedByAirstream Forums1473540801.934078.jpg
Old 09-12-2016, 03:40 PM   #5
stephenb's Avatar
Hutchinson , Kansas
Yep
Old 09-12-2016, 10:30 PM   #6
New Borockton , Alabama
Images: 21
Don't cut yourself short. Looks great!
Randy 208-514-8950
www.bestconverter.com
Converters, Inverters, Trimetric, EMS, Zamp Solar, Lifeline Batteries
Old 09-13-2016, 08:40 AM   #7
2014 25' FB International
Metuchen , New Jersey
Looks great!
Did you use the same battery connection cables or did you attach new ones?
GenXair is offline   Reply With Quote
Old 09-13-2016, 11:48 AM   #8
Brav's Avatar
Actually a good idea for mounting the 702.. if you ever changed your mind, you could always just buy a replacement door!
2010 LR RR S/C
Old 09-13-2016, 11:19 PM   #9
stephenb's Avatar
Hutchinson , Kansas
Originally Posted by GenXair View Post
Looks great!
As per lewisters recommendation I bought 4 gauge welding cable and made connections. The welding cable was really easy to manipulate.
Old 09-13-2016, 11:26 PM   #10
stephenb's Avatar
Hutchinson , Kansas
Smile
You know I just couldn't figure out were and how to run the wire for the monitor. I figured the charger converter was there why not. It is a little bit of a pain reading the monitor from where I minted it so I ordered a dongle for the Bluetooth and am running the app on my phone. Works great. I was even looking at it from my tow vehicle running down the road. I'll just use the 702 monitor as a backup to my smart phone app.
I never thought about just replacing the door if I want to put the monitor somewhere else. Thanks!
Moving Rear Queen Bed Kota Classic Motorhomes 15 05-02-2014 03:28 PM
Reading Lights Under Front Cabinets in Bedroom 25FB KJRitchie 2006 - 2010 Classic (all lengths) 2 05-18-2013 09:44 AM
Safety question about battery located under the bed bkahler General Motorhome Topics 47 01-24-2013 11:22 AM
Intermittent Under-Cabinet Light - '09 25FB Intl bbherb Lights - Interior & Exterior 2 03-15-2012 08:47 PM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-19-2010 12:57 AM
