08-14-2016, 10:23 AM
#21
2008 23' Safari SE
Oklahoma City
, Oklahoma
I've read and reread this and the others Idroba listed and I'm not sure with 2X12 batteries do I remove just the one negative terminal or can I remove the jumpers instead? My original OEM Lifeline's 8 year old batteries finally packed it in I believe. Had them on a trickle charger and yesterday they read 10.8. Need to buy new but think I'll go Interstate wet cells until full retirement in a couple more years when I plan on going the 6 V route.
Thanks Idroba for all the great information.
Mike
08-14-2016, 12:34 PM
#22
Washington
, Missouri
Everyone, I thought I had referenced it in my post that included this thread but looking back I forgot to reference.
Unfortunately IRDOBA passed away last spring. He was very generous with his time and advice. This thread is just one of many that I have saved for future reference.
Rocket53 you may want to post your questions to the thread below.
Here is a recent thread re battery connections and the link to the discussion started on another thread.
http://www.airforums.com/forums/f449...ed-154343.html
I'd have to re-read IRDOBA's and Lewster's threads or maybe others to find the exact reference but based on that advice as I remember it I have been disconnecting the neg terminal and have had no parasitic draw problems. OTRA15 did ask the question (in the above thread #11 & 28) on disconnecting the interconnect on the neg side but I don't believe ever got an answer.
I have some work at the AS this week and have that question on my list. Certainly the nut for the interconnect (jumper) is much easier than disconnecting the post connection.
08-14-2016, 12:41 PM
#23
Naples
If your battery connections are factory stock, the should be wired with the positive load to battery 1 and load negative to battery 2.
If that is the case, simply remove one connection from the parallel cable between the negative battery posts and that should act as a complete disconnect, as it will isolate the two batteries from each other.
Lew Farber
lewster
08-14-2016, 02:15 PM
#24
Washington
, Missouri
Lew...Perfect and as always a huge thanks
08-16-2016, 09:30 AM
#25
LEV ZEPPELIN
2004 19' International CCD
Chicago
You guys beat me to it.
I just spoke with customer service at Interstate Battery and they confirmed the above: If you have 2 batteries and the two jumpers (red and black) going from one battery to the other, you can just disconnect the Black one and that will eliminate any phantom draw. It will not stop the batteries from slowly draining if stored a month or two. In that case use a trickle charger.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
08-18-2016, 10:08 AM
#26
Naples
You have hit on one of the major disadvantages of liquid cells vs. AGM batteries; namely, their internal resistance and the associated self-discharge rates.
With their much higher internal resistance values, liquid lead acid batteries have a 12% (approx.) self-discharge rate. In contrast, AGMs like Lifelines have around a 3% self-discharge rate and will far outlast liquid cells when in fully isolated long term storage.
Lithiums are even lower in their self-discharge rate, and will easily last up to a year without boost charging when isolated.
lewster
08-18-2016, 04:38 PM
#27
2015 30' Classic
Pleasanton
Lew Farber
Lew, did you have a brain fart? Removing the black jumper will not act as a complete disconnect.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
08-18-2016, 04:45 PM
#28
Sag Harbor
, New York
But removing both the red and black jumper would do so? [one end of each jumper that is]
08-18-2016, 04:57 PM
#29
2015 30' Classic
Pleasanton
Correct, as the late Idroba pointed out, removing both parallel jumpers will effectively disconnect both batteries.
Al, K6IV
08-18-2016, 06:43 PM
#30
2012 25' FB Flying Cloud
Celina
, Ohio
I just installed a quick disconnect switch between the ground load wire and the second battery, when I turn to disconnect position there is no power in the trailer
Gary
08-18-2016, 07:21 PM
#31
2015 30' Classic
Pleasanton
Gary
Yes, that will work as well!
Al, K6IV
08-19-2016, 10:17 AM
#32
Washington
, Missouri
Gary
Hey Gary any chance you can post a snapshot?
08-19-2016, 03:40 PM
#33
Naples
Lew Farber
SORRY GANG!!!! (Thanks Alan for the heads-up)
Wasn't thinking properly!! Must be the smoke here in SO Cal (where I am presently)
BOTH PARALLEL JUMPERS...... OF COURSE!!!!
lewster
08-19-2016, 05:15 PM
#34
2007 22' International CCD
Corona
More phantom load information
Lew,
Welcome to smoky SoCal.
I can't even get to my AS right now...I'm at the Riverside end of the 15, and the AS is up by Victorville.
Son, wife, and grandkids managed to sneak through to Ft. Irwin yesterday. It's a smoky mess up there.
08-19-2016, 07:06 PM
#35
Celina
, Ohio
08-19-2016, 10:49 PM
#36
Washington
, Missouri
Perfect thanks Castaway for the pic and Alano and Lewster for the "both parallel jumpers" confirmation.
