Old 08-18-2016, 05:57 PM   #29
2015 30' Classic
Pleasanton , California
Correct, as the late Idroba pointed out, removing both parallel jumpers will effectively disconnect both batteries.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 08-18-2016, 07:43 PM   #30
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
I just installed a quick disconnect switch between the ground load wire and the second battery, when I turn to disconnect position there is no power in the trailer
Gary
Castaway is offline   Reply With Quote
Old 08-18-2016, 08:21 PM   #31
2015 30' Classic
Gary
Yes, that will work as well!
Al, K6IV
Old 08-19-2016, 11:17 AM   #32
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Gary
Hey Gary any chance you can post a snapshot?
CruizinDux is offline   Reply With Quote
Old 08-19-2016, 04:40 PM   #33
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by lewster View Post
If your battery connections are factory stock, the should be wired with the positive load to battery 1 and load negative to battery 2.
If that is the case, simply remove one connection from the parallel cable between the negative battery posts and that should act as a complete disconnect, as it will isolate the two batteries from each other.
Lew Farber
SORRY GANG!!!! (Thanks Alan for the heads-up)
Wasn't thinking properly!! Must be the smoke here in SO Cal (where I am presently)
BOTH PARALLEL JUMPERS...... OF COURSE!!!!
Old 08-19-2016, 06:15 PM   #34
2007 22' International CCD
More phantom load information
Lew,
Welcome to smoky SoCal.
I can't even get to my AS right now...I'm at the Riverside end of the 15, and the AS is up by Victorville.
Son, wife, and grandkids managed to sneak through to Ft. Irwin yesterday. It's a smoky mess up there.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 08-19-2016, 08:06 PM   #35
Castaway's Avatar
Celina , Ohio
Old 08-19-2016, 11:49 PM   #36
CruizinDux's Avatar
Perfect thanks Castaway for the pic and Alano and Lewster for the "both parallel jumpers" confirmation.
More electrical phantom loads information idroba Batteries, Univolts, Converters & Inverters 5 09-30-2014 02:06 AM
Phantom load in tow vehicle Chuck Tow Vehicles 31 11-16-2011 07:49 AM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 10:15 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 08:36 AM
battery: phantom load, or normal discharge? Chuck Batteries, Univolts, Converters & Inverters 12 08-25-2004 01:13 AM
