Originally Posted by mefly2
Looking to hear from someone who has mixed group 24 Lifeline batteries with either Group 27 or 31 AGM. Can they be charged together or must they be charged in separate individual banks?
We plan to add two AGM batts to the existing two Lifelines as supplied by AS with the solar option. The main concern is adding the weight to the tongue if we install the batts under the front bed ... your thoughts?
Thanks in advance.
You will need a second charging source, as the absorption times vary for any given size of batteries. Also, as Jim said, any batteries in a given battery bank should be of the same size, and preferably the same age and manufacture date.
You should not inter-connect 2 battery banks of different size and age to a single charge source as they will never be properly charged; one bank will get more charge and the other less charge, and any draw will not come out of the 4 batteries evenly. It would be preferable to keep the 2 banks separate and use a marine manual combiner switch to connect bank #1 to the trailer, and then be able to switch to bank #2 when #1 gets depleted.
The Xantrex Echo charger will get the job done, but has no adjustments for the voltages to connect and disconnect the two battery banks. A better choice (IMHO) is the Magnum Energy Smart Battery Combiner:
Smart Battery Combiner (ME-SBC) | Magnum Energy, Inc.
This is fully adjustable for voltages and will pass thru up to 30 amps from your fully charged #1 bank top the #2 bank, according to the settings on the panel. It is also water resistant and very easy to install.
