Old 08-04-2016, 11:00 AM   #1
Firemntom's Avatar
Manhattan , Illinois
Maybe a problem
Well I am trying to get some lights on in my 71 Tradewind.
I ordered a new converter from Best Converters 45amp. I look at my Univt and it is wired with all red wires and just 3 circuits being used. I was hoping to find the pink, Browns and all the other colors that the wiring diagram shows.
Do you guys think this is a rewire?
The trailer looked very original.
I have to figure out how and post pictures when I get a chance.
Tom
Firemntom is offline   Reply With Quote
Old 08-04-2016, 11:10 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Take a long enough wire directly from the battery. That wire will be hot so cap or tape it till you are ready to use it. One by one remove a wire from the output of the power supply and touch the battery wire to it. See what is then powered and you can identify which circuit is which. You can the label them as to the colors of your schematic for future reference.
2004 Excursion 4x4
Old 08-04-2016, 11:58 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would put a fuse in the wire just in case you have a short or touch the ground/common side of the circuit.
Having and electrical problem with TV maybe toastie Batteries, Univolts, Converters & Inverters 4 07-30-2011 01:06 PM
Maybe a dumb question (maybe not) kamadeca General Interior Topics 11 04-05-2009 03:16 PM
Weird turn signal problem, maybe TV related AxelBruijnis Lights - Interior & Exterior 25 09-17-2008 04:28 PM
Trip report (long and maybe boring) mkeith54 On The Road... 4 07-26-2002 10:39 PM
