Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 11-19-2007, 12:22 AM
mrmossyone
mrmossyone's Avatar
Profile:  1975 Argosy 24
Collierville, Tennessee
electric jack
My electric jack just stopped working, I have the camper lugged in and still nothing from the lift. Has anyone had a problem w/ maybe the switch going bad or anything? I saw no blown fuses anywhere either. It never smelled or started working strangely so I don't think it's the motor (as in burned up). I guess I will have to see if I'm getting power to the lift, have to buy a tester. Thanks for any help.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
Get rid of these ads... register today, it's FREE
Old 11-19-2007, 05:12 AM
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix, Arizona
There should be an inline fuse in the wires at the hitch. I just had to replace mine because the old one was badly weathered. A small volt / ohm meter is a good investment when working on these problems. Home Depot sells them for around $15.
Richard
Charter Member Four Corners Unit
Old 11-19-2007, 09:00 AM
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
If you have a voltmeter stick a straight pin in the side of the wire leading to the jack motor and test for voltage from the pin to tongue ground. If you have voltage there it is either the switch or the motor. If no voltage the inline fuse to the jack is most likely blown.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 11-19-2007, 10:35 AM
mrmossyone
mrmossyone's Avatar
I had already checked the fuse and it was good, I replaced it anyway and no go. Went and bought a tester and there is power to the switch. I put a new switch in and it was the switch. Problem now is the only 4 prong switch I found is only on/off so I can only raise it....hehe ...not funny. I'm looking for another switch.
Heinlein
Old 11-19-2007, 01:36 PM
HowieE
HowieE's Avatar
Look up the jack manufacturer. Odds are they may just send you a switch. I sent my complete jack head in for service and no charge.
Good Luck
Old 11-19-2007, 02:02 PM
Lumatic
Marshall & Flordemayo
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia, New Mexico
If you don't have one get or make a hand crank for emergencies. Take off the jack cover and the crank engages the shaft so you can jack without juice.
The Lumatic is in my head
vB code is On
Pingbacks are On
Electric Jack niftypkg Jacks, Stabilizers, Lifting and Leveling 9 02-25-2007 06:09 PM
Electric Jack scf31 Jacks, Stabilizers, Lifting and Leveling 2 06-18-2006 06:16 AM
Electric Jack Dbraw Jacks, Stabilizers, Lifting and Leveling 17 05-22-2006 05:33 PM
Electric Jack Devoman On The Road... 12 09-19-2005 03:59 PM
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 08:32 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
