Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-08-2009, 06:26 AM   #1
Profile:  1978 29' Ambassador
Indiana , Pennsylvania
Marinco Electrical Connection
Has anyone installed the marinco electrical inlet on their Airstream. If so, is there a junction box between the outlet and main circuit breaker where you tie in? I'd like to make a clean electrical connection. Should I stay with the 30 amp? Any thoughts would be appreciated. Thanks!
Roadrunner is online now   Reply With Quote
Old 11-08-2009, 08:37 AM   #2
Profile:  , Minnesota
Images: 59
I don't think there should be a junction box, but I'm not familiar with the '78 Ambassador.
If you put in a 50a inlet you will need more room to mount the inlet, heavier wire to the main breaker, and the fittings are more expensive. But you can run everything at once.
Name:	Elec Inlet 003.jpg
Old 11-08-2009, 09:34 AM   #3
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
Michigan , The Great Lakes State
I'm hooking up my Marinco today and finding out what a pain to run 30 amp wire from Marinco to breaker box, the pain is at the Marinco end, would you have any pictures of your hookup.
Toastie
visits our web site www.travelingvintage.com
toastie is offline   Reply With Quote
Old 11-08-2009, 10:43 AM   #4
Images: 59
I added a 4x4 extension box to provide enough space behind the receptacle to turn the wires and head them up through 3/4" plastic conduit. I believe I used #6 Stranded THHN, mine is a 50a though, you could use #10AWG for a 30a.
Here's a closeup of the box, and a wider view with the box at top center.
Name:	Elec Inlet 006.jpg
ID:	90541   Click image for larger version
Name:	Elec Inlet 008.jpg
Old 11-08-2009, 11:04 AM   #5
toastie's Avatar
1955 22' Safari
Smart, very smart.............thanks
What is advantage of Marinco type power inlet? SilverHoot Electrical - Systems, Generators, Batteries & Solar 5 07-15-2009 01:58 PM
Are Marinco and Hubbell interchangable? pauly g Electrical - Systems, Generators, Batteries & Solar 2 03-16-2008 07:53 PM
failed electrical connection on brakes on one side only Tin Diesel Brakes & Brake Controllers 3 04-20-2006 03:02 PM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 10:06 PM
Wi-Fi connection? Krazykraut Airstream Motorhome Forums 8 11-25-2002 12:46 PM
