Old 05-16-2008, 01:40 PM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Both items plug into the outlets. I have seen the volt meter at CW and the polarity tester at HD.
Richard
Old 05-16-2008, 01:43 PM   #16
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Originally Posted by CanoeStream
I also keep an eye on whether the auto-set fridge switches away from electric and over to gas.
You guys are really making me jealous! I have to go outside and access the back of the fridge to switch it from one source to another. Dang, AC, microwaves, monitor panels, auto-switching fridges, what's next
Stephanie
Old 05-16-2008, 02:33 PM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I have the volt meter plugged in constantly over the kitchen counter. It obviously shows whether we have power, but it's always there and on to monitor what we have coming in. It's not unusual to see that voltage fluctuate under load. It might save you an A/C compressor if campground's voltage sags under a hot summer's sun.
Keep in mind that the particular model that Richard and I have has a variance factor of plus minus 10%. If I had to do it over, I'd try to buy a unit that is a little better than that.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-16-2008, 02:59 PM   #18
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by Stefrobrts
You guys are really making me jealous! ..... Dang, AC, microwaves, monitor panels, auto-switching fridges, what's next
I had another thought -- the automatic toilet seat drops to the default position (down) if the power goes out.
Old 05-16-2008, 03:34 PM   #19
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Jack
Since we are having our 68 Ambassador renovated, I would like to upgrade to a better unit....(voltage tester, I mean) as we will have a new 68 when we are done....do you know of a better voltage tester that has a lower variance, Jack?
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is online now   Reply With Quote
Old 05-16-2008, 03:45 PM   #20
Excella CM's Avatar
1978 31' Excella 500
Venice , California
A nobler answer to the problem would be to wire in a small socket and use a NEON GLOW LAMP. They use negligible power, have a comforting glow, and last forever. For example see:
B1A NE-51 NE51 Neon Lamp Bulb Qty 10 - eBay (item 130221769492 end time May-18-08 07:34:07 PDT)
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-16-2008, 04:21 PM   #21
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We have one of those in the bathroom. It's pretty unobtrusive, and gives just enough light to see the toilet, and the way back to bed in the middle of the night. Burns maybe a watt.
Old 05-16-2008, 04:49 PM   #22
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Spoken like someone with a newer trailer Caravels don't have monitor panels, and the fridge has no readouts or lights of any kind. But I did find a little led nightlight for now and plugged it in next to the intellipower and it lit up when I plugged the trailer in, so I think that will do the trick for the moment. I like the idea of one of those poliarity testers too, I'll have to look for one of those.
I wasn't sure you'd have a monitor panel but thought you may have a (newer) fridge...which might have a light.
Guess I am still excited about repairing my gauges (finally!) last week!
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 05-16-2008, 05:01 PM   #23
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
It's a new fridge, but it still doesn't have any lights or indicators on it. I guess because it's such a mini - no frills. I'd be excited about getting your guages working too. I always wished I had a monitor panel like the big trailers!
Stephanie
Old 05-16-2008, 05:50 PM   #24
jcanavera's Avatar
Fenton , Missouri
Images: 143
At one time Camping World sold a digital unit. I think its variance level was about 5%. The analog dial one I have today didn't cost very much. If you look at one, check out the specs.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-16-2008, 07:02 PM   #25
SteSpot's Avatar
1968 28' Ambassador
Jack
There is no CW near me and maybe I should check with an electrician...they know about all the good stuff.....One time we had to use an extension cord to reach the campground plug in and the cord somehow had the reverse polarity....my little polarity tester let me know that.....am not sure what would have happened but I reversed the cord and the polarity was correct and my trusty little tester told me...of course, extension cords are not a good thing anyway. thanks, paula
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 05-17-2008, 11:35 PM   #26
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Jack
Hi, I have the three light [polarity] tester plugged into an outlet to the left of my door; If you only have one tester I would for sure have this one. Also in this picture, I have the analog voltage tester plugged into the outlet near the left side of my hood vent. And on the right side [hard to see in picture] I have the digital voltage tester with a glowing night light plugged into it. The digital tester will give you volts, hertz, and wattage draw on anything plugged into the recepticle on the tester. You may want to click on picture to enlarge it, if your eyes are like mine.
Name:	My Picture CD 424 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Making the Interior Your Own TBRich Upholstery, Blinds, Walls & Interior Finishes 58 07-26-2008 02:12 AM
Making tire changes SRW Tires 7 03-16-2008 05:35 AM
Making the bed in the kitchen Sparkygus 2006 - 2010 International 5 05-17-2007 05:50 AM
making my own awning....... AnnZ3 Awnings 11 09-03-2004 07:42 AM
making a stormdoor? sovereign Doors & Locks 4 07-29-2002 08:12 AM
