Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 05-16-2008, 11:54 AM   #1
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Making sure the power's on
Does anyone have any clever ideas for knowing if you're plugged into 110v or not? I have had several occasions where we plugged into power at the campground, and either forget to throw the breaker to turn on the power or turned on the wrong one on the campground power box. Since all our lights and accessories are 12v, we usually don't notice until a couple hours later when we wonder why the fridge isn't cold yet, or the battery starts to run out and the lights go dim. Does anyone else have this problem with their vintage, mostly 12v unit? As far as I can tell the Intellipower just sits there and blinks whether it's plugged into shore power or not. Is there any other easy way to tell if you're plugged in?
Stephanie
Our family photo blog
Old 05-16-2008, 11:57 AM   #2
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Stef,
Plug a night light into one of the 110V outlets or turn on the A/C. If you have a microwave, see if the clock blinks 12:00.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 05-16-2008, 12:07 PM   #3
SteSpot
SteSpot's Avatar
Profile:  1968 28' Ambassador
Venice , California
Little tester
Actually there is a little tester that you can plug into your outlet that will tell you if your polarity is correct. If all the little lights are green, everything is fine. If the polarity is wrong, it will let you know....I don't know what it is called....perhaps a polarity tester but I keep one handy and use it each time we hook up.....it let's you know if there is something not right with the 110 hookup.....paula
Suite Spot
WBCCI # 22353 Air#13593
1968 28'Ambassador
SteSpot is offline   Reply With Quote
Old 05-16-2008, 12:10 PM   #4
SteSpot
SteSpot's Avatar
Venice , California
It looks like this: Circuit Siren™ Audible Circuit Breaker, Continuity, and Polarity Electrical Tester Kit - Content
Suite Spot
1968 28'Ambassador
Old 05-16-2008, 12:17 PM   #5
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i have this one, it tests gfi's too.
Gardner Bender Ground Fault Indicator Tester; 1/Cd, 10Cds/Master - GFI-501A at The Home Depot
i'm going to use my computer UPS. it beeps when the power goes out.
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
Old 05-16-2008, 12:19 PM   #6
Stefrobrts
Stefrobrts's Avatar
That's a good idea. No AC or microwave, but a little nightlight or something would probably do the trick.
Stephanie
Old 05-16-2008, 12:22 PM   #7
SteSpot
SteSpot's Avatar
Venice , California
That looks like a good one.
guess I am going to have to upgrade to that one although I don't think I have any gfi outlets in our trailer.....perhaps we should.....thanks, paula
Suite Spot
1968 28'Ambassador
Old 05-16-2008, 12:29 PM   #8
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
This is what the outlet opposite the door on my trailer looks like. Volt meter and polarity checker, can't miss them when you walk in.
Richard
Charter Member Four Corners Unit
Old 05-16-2008, 12:32 PM   #9
SteSpot
SteSpot's Avatar
Venice , California
Very cool
Thanks Richard....that is perfect....paula
Suite Spot
1968 28'Ambassador
Old 05-16-2008, 01:17 PM   #10
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Why not just look at your monitor panel or fridge?
Bill
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
BillTex is offline   Reply With Quote
Old 05-16-2008, 01:28 PM   #11
Stefrobrts
Stefrobrts's Avatar
Bill
Spoken like someone with a newer trailer Caravels don't have monitor panels, and the fridge has no readouts or lights of any kind. But I did find a little led nightlight for now and plugged it in next to the intellipower and it lit up when I plugged the trailer in, so I think that will do the trick for the moment. I like the idea of one of those poliarity testers too, I'll have to look for one of those.
Stephanie
Old 05-16-2008, 01:34 PM   #12
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Richard, is that a plug-in meter or actually part of the outlet. The perspective throws me off.
Stephanie, I keep one of these plugged into an unused outlet visible from the door of my Safari. Like Richard's, the bonus is that it tells me if I have a voltage brownout and better not run the A/C. [ We won't tell the rest of the country how little we have to run our A/C...] I also keep an eye on whether the auto-set fridge switches away from electric and over to gas.
Old 05-16-2008, 01:34 PM   #13
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 33
Yep, nightlight or tester. I actually like the tester as it has caught a few miswired boxes at campgrounds.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 05-16-2008, 01:35 PM   #14
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I have three of those luminous? type nightlights that sort of glow blue or green, come in very small sizes and also come in multi packs. I have one plugged in the bathroom, an outlet near the floor by the entry door and one in the kitchen. they give off a very soft glow but just enough illumination to make your way into the bathroom or get up to get a drink. My newer A/S does not have a "power on" light on the monitor panel.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Making the Interior Your Own TBRich Upholstery, Blinds, Walls & Interior Finishes 58 07-26-2008 02:12 AM
Making tire changes SRW Tires 7 03-16-2008 05:35 AM
Making the bed in the kitchen Sparkygus 2007 International CCD 5 05-17-2007 05:50 AM
making my own awning....... AnnZ3 Awnings 11 09-03-2004 07:42 AM
making a stormdoor? sovereign Doors & Locks 4 07-29-2002 08:12 AM
