04-13-2013, 09:40 PM
2008 25' Classic
Full Time
Maiden Trip Cut Short: Converter or Batteries Failure
I purchased a 2008 Classic 25fb two weeks ago from an AS dealer. I had a local Airforums inspector and what I thought a pretty good PDI/orientation and was pretty confident with all the systems. This AS has been lightly used to where it appears not much was used in it. The stickers on the shower walls are still there!
We took or maiden trip this weekend to a nearby state park. Everything seemed fine. At about 2am in the morning I woke up and could see a flashing light in the corner of my eye. It was the Atwood LP Gas detector. The light was flashing amber every 8 seconds. I turned on the lights and saw on the face plate it meant a fault. I figured I would read up on it in the morning and after several minutes the flashing amber turned to flashing green.
In the morning I found the Atwood LP Detector manual and it explained the amber flashing light it due to low voltage. I had a voltmeter and checked the battery posts and the voltage was under 10v! I was hooked up to power and the microwave worked. The converter is under the bed in this 25FB and I measured the voltage across the outputs for the battery and the voltage was 9v.
I cut our trip short and drove back to the dealership service department today and have left the trailer there for them to work on it. Luckily the purchase included a 90 warranty.
If the batteries are old and failing would this cause the converter readings at the outputs to be this low? The readings should be 13.8v to 14.1v according to the AS manual.
I noticed a few days ago when we were loading the rear 3 light dinette lamp would change intensity, lower then brighten occasionally. The 4 Thin-lite fluorescent lights where steady. Was this a symptom of converter failure?
I think I have a Magnetek. If the dealership decides to replace the converter and batteries should I opt to spend the extra money and upgrade the converter to a 3 stage converter?
I'll probably replace the batteries irregardless. I believe the batteries are probably the original batteries, Interstates.
Driving the AS to the dealership was about a 90 minute drive and the batteries didn't seem anymore charged. How do you test if the tow vehicle is charging the batteries. If you hook it up can you measure the change in voltage on the batteries or on the converter panel.
Thanks for any assistance.
Kelvin
04-13-2013, 09:57 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I will wait for the electrical guys to chime in, but I would say that new batteries and a new 3 stage converter would be a no brainer. Especially if you do any boondocking.
Dan
04-13-2013, 10:04 PM
1978 31' Excella 500
Genoa
, Nevada
A lot of us have found that towing doesn't charge the trailer batteries very much.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
04-13-2013, 10:59 PM
1999 25' Safari
On
, the road
Getting the obvious question out of the way. Is the switch for the converter in the "on" position? Is the 120 outlet the converter is plugged into actually getting 120v?
I'd go for a 3 stage converter. Better for the batteries. (Though we somehow have gotten 2 bad batteries from Interstate. Can't see it was anything I did to screw em up)
Speaking of batteries.. How old are they? How long was the trailer sitting on the dealers lot? Wouldn't hurt to get them load tested.
04-13-2013, 11:10 PM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
Ours recharges well on an all-day drive. Not so much during a short hop.
04-14-2013, 06:10 AM
2008 25' Classic
Full Time
In the two weeks since delivery we have spent a couple of evenings with it in its covered storage with the electricity plugged in while we were there. The day before we left on this trip we had the trailer plugged in for 24 hours to run the fridge. When hitching up in storage to leave the power jack ran normal, unhitching at the state park it was normal. During the evening of the first night in the trailer we had the Thin-Lite ceiling lights on from about 7:00pm until about 10:30 when we went to bed. I didn't notice if the dinette light was fading in our out. None of this should've drawn done the two batteries.
I'm not sure I'm confident to attempt to swap out a converter to a 3 stage converter.
Do you have to make major modifications to the footprint of the existing space to switch to a 3 stage converter? I'm thinking get the current one fixed/replaced under the warranty to get me by then figure out what it takes to switch to a 3 way. In the mean time get a new set of batteries.
Kelvin
04-14-2013, 06:25 AM
1971 31' Sovereign
fort myers
You can test the batteries for cell failure. You can test the converter/charger,as well. Could be something as simple as a bad connection.......rusty washers/ionization/moisture will cause that. I don't see the reason for cutting your trip short. One thing to remember....camping was here long before the discovery of electricity.
04-14-2013, 07:05 AM
Sounds like a classic case of worn out batteries since they were charged up before you left on your trip.
Until I changed to a 3 stage converter charger new batteries lasted only about 2 years.
The three stage converter from bestconverter.com is a "plug and play"--it is the electrical guts and goes into the Paralax box. If you can't decide what you need on line, call technical support. They are responsive and well informed.
Lots of handy people have changed their own. I had the shop change mine as I am big and old, don't bend that way any more and my converter is in an awkward place in between the twin beds.
04-14-2013, 07:15 AM
Retired.
, At Large
If the trailer is plugged in to shore power, it doesn't really matter how good or bad, or even if, the batteries are. It should work just fine with new, or old batteries, or missing batteries. Make sure the use/store switch is in the "use" position. Check the voltage at the terminals with a volt meter, it should read at least 13 volts when plugged in. Make sure the use relay is functioning, if it isn't, the converter will not charge the batteries.
04-14-2013, 08:06 AM
2012 28' International
New Orleans
, Louisiana
Convertor swap is easy,new one about $200. Best Convertors. Learn how to check your batteries for dead cells.
Good Luck
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
04-14-2013, 09:29 AM
Alamo Heights
The kit that handn refers to is probably going to be the easiest route for you to get to 3-stage charging, because your converter is in that integrated "power center" under the bed with the 12V distribution panel as part of the same assembly. I don't know how hard those are to fix, since my trailer has a separate fuse block and floor-mounted converter. The challenge would be getting a dealer to replace with an aftermarket converter under warranty, but since it's a 90-day dealer question vs. the manufacturer warranty you may have a shot. It looks like they're price-competitive at retail, though I've no idea what wholesale prices are like.
The converter may have been on its way out when we inspected the trailer... at the batteries when plugged in it was over 13v but it wasn't pushing 14. I should have considered the fact that it's a one-stage charger at the time, I chalked it up to the fact that the trailer had been plugged in before they moved it to where we could get up to see the roof, etc. and plugged it in again. I don't know if a bad battery would reduce the voltage while charging that much, but it seems possible... and I'm sure I didn't unplug the trailer and watch the battery voltage over the time we were looking over the trailer. That would have given us more of an idea of the battery condition.
— David
04-14-2013, 09:36 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Changing out the OEM converter for a 3 stage unit from Best Converters took about an hour. Fortunately on the 25FB, the converter is under the bed at the end of the short hallway, so I could lie down to see things with a flashlight.
Just be sure the shore power is unplugged and the battery wires are are lifted off the battery terminals before starting.
04-14-2013, 09:41 AM
Olympia
My philosophy is always check the simple stuff first. Are your battery connections clean and tight? How do the cables look?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
04-14-2013, 10:52 AM
2008 25' Classic
Full Time
The battery connections look good at the terminals and the terminals have a mild coating of anti corrosion spray. My inspector checked all this but we can't find everything. The weekend trip was a shake down cruise and we are glad we found out about this issue before leaving on a longer trip in a couple of weeks. I'm learning more about this stuff also.
Thanks for everyone's comments.
Kelvin
04-14-2013, 12:15 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Well, that's what a " Shakedown" is for, to find issues to take care of. I put new multi-stage convertors in 2 different trailers, including our current one. Ours are easy to get to and are located below the front sofa-bed. You got nothing to lose by asking if the dealer will do it but don't be surprised with their response. Maybe you could ask them for a credit for what they would pay for the one they carry and put it towards a multi-stage one and put it in yourself. That is, if they were going to do it under warranty anyway. Whichever way you go you will be satisfied once it's done and installed.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
04-19-2013, 02:19 PM
2008 25' Classic
Full Time
The dealership where I purchased my preowned 2008 Airstream Classic 25 has determined the issue is with the batteries. Replaced the two old Interstates with two new Interstate Grp 24s and tested the charger over 24 hours. They are not billing me for their labor or batteries. What a nice surprise! I guess they felt the batteries should have been replaced when they took the trailer in trade. We are on the road next week to Roaring River State Park in Missouri to meet our college daughter. New tires, new batteries, what can go wrong, knock on aluminum
Kelvin
04-19-2013, 03:03 PM
Wise Elder
2010 30' Classic
South of the river
Rarely, batteries will short out internally and pull down the voltage from a good converter. The converter should work fine without the batteries, and if disconnecting the batteries clears up the problem then, well, you've found out what was wrong.
The batteries will overheat, boil over, and sometimes explode when this happens. If when you disconnect the batteries you observe that they're in one piece and have the correct amount of electrolyte in them, then the problem is probably somewhere else.
It is common for the wiring to come loose, usually in the circuit breaker area. That would be the first place I would look, along with checking that the output wiring to the Magnetek is clean and tight.
It's really rare for the Magneteks to fail. They're not bad converters, but the fan noise is irritating, and they take longer to recharge the batteries than a 3-stage converter. I haven't replaced mine -- the recharge times don't matter to me much because I don't use a generator and because I have shore power at my storage location, so if I'm charging from shore power, I'm doing it overnight anyway.
See http://www.airforums.com/forums/f449...ry-102788.html
Common problem and many tow vehicles require adding a fuse or some other minor change to charge batteries. If you do have a shorted cell in your trailer batteries you may have blown a fuse in the charge line from your tow vehicle.
I get reasonably good charging performance from my tow vehicle, and check it with a handheld ammeter from time to time. Mine is an old magnet-style, inaccurate but usable, these days they have electronic ones that are much better.
You can also wire in a DC ammeter in the trailer and check it before leaving, when stopping for fuel, etc. I've done this in my truck camper, because the charge line is the only source of charging -- the converter doesn't charge the batteries in that rig.
04-19-2013, 03:37 PM
1999 25' Safari
On
, the road
Good luck with the Interstate batteries. My Airstream appears to be eating them. One replaced after 8 months under warranty and it now the other 10 months old one is about dead and the 2 month old one is having troubles as well. They are normal 12v group 29 deep cycle. Trying to get some credit form Interstate for them to put towards 6v golf cart.
Not impressed.
04-19-2013, 04:20 PM
Wise Elder
2010 30' Classic
South of the river
Not impressed.
Batteries don't just die.
Are you leaving them sit while discharged? Have they had the electrolyte get too low? Have you checked voltages to see what's going on?
04-19-2013, 04:50 PM
Spokane
This same thing happened to me on our shake down cruise. We had a bad battery and a bad converter. I had them put in a good 3 stage converter and it fit right into the space the old one occupied. It is an IOTA and as I recall it didn't cost a huge amount.
I would seriously suggest you get one of these(a three stage). People have a tendency to leave their trailers plugged in for a long time and a single stage will overcharge and eventually destroy a battery. I sleep much better at night now that I know my converter is working and is not a threat to the batteries.
I don't have a clue what a Magnetek is or how it works but I sense, from what I have read here, that it is a single charge unit. I would replace it some time down the road.
