Old 02-21-2015, 02:05 PM   #15
mefly2's Avatar
2015 25' FB Eddie Bauer
Very well done ...
Old 02-22-2015, 03:35 PM   #16
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Will do a shot of the sub-panel and send it on. For now, though, this is a picture of the dinette. The Magnum is under the rear dinette seat, the 4 Lifeline batteries are under the front dinette seat. All completely hidden. Fabricated a moulding that goes on the floor/wall between the two seats -- that's where batt cables, sensors, T fuse, etc. are located. Also wires for subwoofer which moved under the forward dinette seat as Magnum took its spot. Came out really well. But, for now it just looks like a standard Classic dinette -- which is what I expected.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-22-2015, 07:37 PM   #17
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Images: 135
Lamp
Hi Barry, I like this lamp better than the first one...LOL
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 02-22-2015, 07:54 PM   #18
BAB
BAB's Avatar
2015 30' Classic
Agree. First one turned out to be too large. Also, the person in the SS recliner couldn't see the TV through the lamp....sometimes what looks good in one place doesn't necessarily work somewhere else. You'll get the updated tour at Alumalina!
_________________
ProPride 3P
AIR# 58452
Old 02-22-2015, 08:08 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
A couple of shots of a just completed MSH-3012M and a 3024iX Blue Sky solar charge controller system with a 540 watt solar array. Batteries are temporary, as we are waiting for AM Solar's 400 amp/hour lithium pack (yellow tape lines) to be ready to ship. All systems are operational !
PS: this is in the front storage bay under the front bed of a 27.
ID:	232936   Click image for larger version
Old 02-22-2015, 09:55 PM   #20
2007 22' International CCD
Very nicely done!
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 03-05-2015, 02:43 PM   #21
BAB
BAB's Avatar
2015 30' Classic
Here are a couple of shots of the left side of my closet in the '15 Classic. First one is the Progressive 50 AMP power manager (I put a 110V outlet above it so I can plug in the charger of the battery of the Dyson vacuum). Next to the Progressive is the sub-panel for the Magnum. Not in the picture -- I framed the panel in wood stained and finished to match the cherry in the rest of the trailer. You'll notice I do have "expansion" room in my sub-panel should I decide to shift some circuits from the main panel. Final shot is the control panel. Top left is the IPN controller for the 600W of solar, underneath is the Bogart Trimetric, top right are two banks of 12V switches...operate subwoofer, cell amplifier, WiFi Ranger, refrigerator muffin fans, and a 12V charger circuit. Magnum remote control is on the bottom right. I have some redundancy with these meters, but I REALLY like having the Bogart as I got used to it in my old trailer. I also have an inop switch for a Xantrex 2000 W inverter. I have the inverter as a spare, but it's not wired up -- the Magnum dwarfs what the Xantrex can do. The only 110V switch (so far), puts power into the ice maker. This gives me the option to NOT use it....and the 110V does go through the inverter so I can make ice when I'm boon docking. Whew! Lotsa stuff.
ID:	233663   Click image for larger version
_________________
ProPride 3P
AIR# 58452
Old 03-05-2015, 03:46 PM   #22
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
BAB - can't wait to take the "technical tour" at Alumalina. Your new rig prep is impressive!
SeeMore is offline   Reply With Quote
Old 06-17-2016, 10:21 PM   #23
2016 30' Classic
Casa grande , Arizona
This is a great setup in your Classic. Is there anything you would now do different ? I have a 16' classic so I'm wondering if a year later you would change anything?
Clozzzer is offline   Reply With Quote
Old 06-18-2016, 06:56 AM   #24
BAB
BAB's Avatar
2015 30' Classic
Set-up has been wonderful. Good example: a couple of weeks ago we were at a rally in a park that had an electrical issue (West Memphis, AR). The power went off a couple of times. The first time we were doing some touring. The day was hot and we had left the two dogs in the trailer. When the power in the park went off, the Magnum automatically converted the 12V from my 4 batteries to 120V so the A/C continued working. (I can run the front A/C for about two hours off the batteries.) When we returned to the trailer, I started the Honda EU3000iHandi to generate 120V until the power was restored. I'd also say that the newer Classics need plentiful 12V. Awning, stabilizers, bed, table all use 12V in addition to the usual stuff. To a large degree, Airstream has turned the trailer into a trailer park queen with all the power requirements. By doing all these electrical upgrades, my trailer is totally independent....which I greatly enjoy. I've kept track of what I've invested to customize it the way I want it, and I'm right at $17K. The electrical upgrades (including the generator) are by far the most expensive part. Perhaps the most visibly enjoyable, though, is the dishwasher!
_________________
ProPride 3P
AIR# 58452
Old 06-18-2016, 12:10 PM   #25
2016 30' Classic
Do you have any detailed photos of the placement of the inverter charger? I'm thinking about doing this first and wanted to get a general idea of what's involved to get it done. How did you run the new wires and where do I make the new connections from?
Old 06-18-2016, 12:24 PM   #26
BAB
BAB's Avatar
2015 30' Classic
You can see the placement of the Magnum in post 12. The four batteries are also shown in that post. The space I used for the Magnum is next to the curbside wall under the rear dinette seat. There is a drawer under that seat, but adequate room behind the drawer for the Magnum. You'll see the piping for the outside shower on that wall. (After completing my install, I carefully sealed some heavy plastic between the shower piping and the Magnum (just in case). Water in the Magnum would NOT be a good thing. The AGM batteries fit under the forward dinette seat, though I did have to remove the drawer mechanism. Not a real problem to do this as I just used the front of the drawer as a false front. I ran the heavy battery cables to the Magnum through a chase I constructed on the floor next to the CS wall. I made this out of wood and stained it to match the interior, but you could use aluminum angle as well. If you decide to use Lithium Ion's you'll save a LOT of weight and room. Once my batteries are done (I'm told I should get around 1000 cycles with them), I will go to Lithium. The Magnum controller just needs some reprogramming to do this, and my Blue Sky solar controller will work as well. I have had zero problems with all these electrical mods. I took plenty of time doing the install, and of course, I had several useful suggestions from Lewster. The Magnum documentation is first rate...lots of pictures and very clear install instructions. The hardest part was running wire from the batteries to the inverter and putting in wire from the inverter to the sub-panel. Airstreams are not "user friendly" when you wire from one side of the trailer to the other.
_________________
ProPride 3P
AIR# 58452
Old 06-18-2016, 05:03 PM   #27
2016 30' Classic
Thank you. Also, how did you manage to run the wires under the chassis to the sub panel?
Old 06-19-2016, 11:11 AM   #28
BAB
BAB's Avatar
2015 30' Classic
I bought 3/4" plastic conduit and ran it from the CS to the SS on top of the belly pan. I did have to drill out a few rivets to get access where I ran the conduit into the trailer. I ran the electrical cable through the conduit. Since it was sheathed outdoor cable I have PLENTY of protection and insulation from the elements and potential road hazards.
_________________
ProPride 3P
AIR# 58452
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
'15 Classic - Magnum MSH Install Moving Ahead BAB Batteries, Univolts, Converters & Inverters 0 02-11-2015 02:39 PM
Do I Need to Replace These Magnum Shocks? kennytheecat Shocks 3 04-01-2009 02:40 PM
Just wondering - towing with Magnum? tsprc Tow Vehicles 52 12-05-2008 04:37 PM
Dodge Magnum R/T sieve Member Introductions 16 08-04-2007 08:22 PM
