Old 11-02-2014, 09:38 PM   #1
2013 22' FB Sport
College Place , Washington
low voltage cutoff vs AMP hours used at high amp draw
I have 2x GPL-6CT in my airstream, when I use my convection/micro it draws at 130 amps or so. In theory, I can can run my convection/micro for over an hour before I reach 50% discharge on my battery bank. My Magnum inverter has a low voltage cuttoff settings, to save the batteries which can be set down to 9 Volts.
In practice, I can run the micro for about 35-45 minutes before the voltage is below 9 Volts at a 130amp draw. The moment the micro is turned off, I am at 70% battery and back above 12 volts.
So... does this damage the batteries? Battery is not low based on amp hours, but the voltage is low due to the load.
-Dwight
morgandc is offline   Reply With Quote
how low is too low AC voltage? WineStream Electrical - Systems, Generators, Batteries & Solar 59 12-18-2009 02:56 PM
High Voltage in Mexico cooney Electrical - Systems, Generators, Batteries & Solar 2 12-19-2008 06:01 PM
High Voltage Power lines and batteries safari57 Batteries, Univolts, Converters & Inverters 9 10-31-2006 10:31 PM
High Voltage kooblekidz Mechanics Corner - Engines, Transmission & More... 8 02-05-2004 07:32 PM
BBBBRRRRRRRLOW Serious voltage draw Phaedrus Generators & Solar Power 1 06-15-2003 10:09 PM
