Old 05-17-2010, 05:44 PM   #1
jasper2222's Avatar
1996 25' Excella
Tallahassee , Florida
low voltage at Electric hot water heater
I have a add-on Electric hot water heater "hot rod". It has an electric light that illuminates when the electric hot rod is on. It has worked fine for years. Lately, when you turn off the switch for the electric the illuminator lights stays on, but it is dim. I checked the voltage and I am getting 25 volts, then it drops to 20, 19 and down down. But it may take a hour or more to drop back to Zero. If you unplug the electric going to the hot water heater it drops to zero. Plug it back in, it goes back up. If you unplug the trailer it drops to zero. I checked the plug coming from the hot water heater and no voltage, so evidently the plug is somehow completing a ground.
So any ideas where to start. Maybe the on/off 110 switch is bad and feeding current to that outlet only, and it take the hot water plug to complete the ground?? I don't know but any ideas would be appreciated. Thanks, Richard
jasper2222 is offline   Reply With Quote
To Go All Electric on the Water Heater? Excellaphant 1987 - 1989 Excella 14 07-20-2011 02:20 PM
Rheem 110v electric hot water tank...... toastie Water Heaters, Filters & Pumps 6 10-27-2009 06:46 PM
Hot water pressure low connorsa Full-Timing 4 09-11-2009 01:11 PM
Low hot water pressure??? FBC72 Water Heaters, Filters & Pumps 2 07-29-2007 10:49 PM
Electric hot water on all the time? Kistler Our Community 3 05-13-2003 03:10 PM
