Old 07-04-2014, 09:15 AM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Loose Connection at Negative Busbar
I was disconnecting the trailer when the tongue jack quit working. It had been making noise so I was afraid that it had finally died. A quick check showed the light didn't work either. Whew! A wiring problem is better than replacing the jack.
No power to the jack. No power at the fuse. No power at the positive battery terminal (measured to the ground lug inside the jack). What the ???
Measured to the negative post of the battery and everything is OK. A look at the wiring diagram shows the negative cable runs to a Busbar near the converter. Sure enough, the cable had pulled out. It was crushed like it should be from the clamp screw, but when I went to put it back in, the screw felt tight. I guess a strand of the wire got in the threads and made it feel tighter than it actually was.
With this failure, nothing battery operated was working, including the trailer breakaway switch operating the brakes. Vehicle brakes would have worked as they run from TV battery and ground.
Check your Busbar connections periodically. This would have been a real pain while camping. Luckily I was in my driveway.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-04-2014, 03:31 PM   #2
2005 19' Safari
GLENDALE , AZ
We had the same problem right after taking delivery of our 19-foot Bambi in 2005. Guess that guy was still working there in the factory.
Fuse on battery negative crispyboy Batteries, Univolts, Converters & Inverters 23 01-27-2008 02:12 PM
12v Negative Problem jrk247 Electrical - Systems, Generators, Batteries & Solar 24 10-01-2006 08:48 AM
