Old 05-14-2015, 12:29 PM   #1
sharwest9782's Avatar
1975 25' Tradewind
McMurray , Pennsylvania
Looking for help with Univolt converter replacement
I'm replacing my current electrical setup. I think I know what I need, but want to check with the experts. 😀My AS TW '75 has a 40amp converter but I'm pretty sure it is not original. I have this blue plate that seems to indicate a 45 amp was original. Does this seem right? I was planning to go with the PD9245 converter/charger w charge wizard. Also the 12v fuse box seems original and I'm thinking I should replace with the blade type? Also what is the little breaker w the glass fuse(bottom right of photo)? Do I need it? What is its modern equivalent? I've included some photos. Thanks! Once I get this working I need to figure out why the 12v lines in the old AC area appear to be dead... Click image for larger version
Name:	ImageUploadedByAirstream Forums1431627923.875322.jpg
ID:	238414Click image for larger version
Name:	ImageUploadedByAirstream Forums1431627942.159955.jpg
___________________
Garden Caravan
reno blog @ https://sharwest.tumblr.com
sharwest9782 is offline   Reply With Quote
Old 05-14-2015, 12:38 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The 9245 will work fine. A new blade type fuse block is recommended.
Some trailers had a fuse in the negative lead from the battery. If you decide to keep that protection then upgrade the fuse and holder.
Old 05-15-2015, 02:05 PM   #3
1975 25' Tradewind
Thanks!!
___________________
Garden Caravan
Old 07-06-2015, 02:02 PM   #4
1990 33' Land Yacht
Chance , Maryland
have a 1990 airstream landyacht with energenius eg3000 series the breaker with the white test button has blown, what do i do, and where do i get a new one?
bjkayla is offline   Reply With Quote
Old 07-09-2015, 08:59 PM   #5
1975 25' Tradewind
I got my converter (Inteli-Power 9245 Converter/Charger 45 Amp w/ Charge Wizard/Pendant (S018-559008)) from AdventureRV.net. I knew what I wanted. But they may be able to help you if you contact them. I did watch a few videos to try to figure out what I needed, and the help here of course.
___________________
Garden Caravan
Old 07-09-2015, 09:35 PM   #6
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Second the inti power. Dang that's a crap link..
http://www.pplmotorhomes.com/parts/c...FdcVgQodfKAGCA
Silverflames is offline   Reply With Quote
Old 07-09-2015, 09:57 PM   #7
1979 23' Safari
Wayland , New York
If you haven't done the fuse panel yet, here's a couple posts I helped some others figure out their mess and replace fuse panel:
http://www.airforums.com/forums/f219...er-133233.html
http://www.airforums.com/forums/f37/...ck-135473.html
Old 07-09-2015, 10:44 PM   #8
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
In my rebuild I changed the location and fuse panels along with the Converter. Good bye UniVolt hello InteliPower along with a Lifeline AGM Battery.
I also added 4 maxi fuses. One for the converter one for the factory trailer feed , one for the new fuse panel above them and one to feed the other fuse panel on the new breaker box.
By the time I was finished I changed the one above the maxi fuses to a 8 position fuse holder note the circuit breakers in it , they replaced the original glass type circuit breakers.
ID:	242579   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
univolt vs. converter help! tinindian79 Electrical - Systems, Generators, Batteries & Solar 4 10-03-2010 10:27 AM
need help on univolt converter 72 Overlander 1 Electrical - Systems, Generators, Batteries & Solar 90 06-25-2009 11:55 AM
replacement for Univolt Converter autoxstream 1993 Excella 1000 7 04-27-2006 09:49 AM
