Old 04-05-2010, 10:52 PM   #1
Ottawa , ON
looking for a 12 Volt Fuse Panel
Hi all.
I have a new converter to install, and I want to also ditch the fuse panel that the Univolt has in it.
Out-of-doors-mart and Vintage Trailer Supply both seem to carry the same one, from Parellax.
Any other ones around that you would care to recommend?
TIA,
Aage
Old 04-06-2010, 01:16 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
You might consider switching to circuit breakers rather than fuses. Do you need the panel more easily accessible, or does the stock location work for you? I'd definitely go for something w/ screw terminals rather than 1/4" push-on terminals...
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-06-2010, 07:35 AM   #3
Ottawa , ON
Do you know of any reasonably-priced 12V distribution panels that use breakers? That, I have not seen at all.
Of course, if things are functioning properly, I won't be going near the fuse panel, and while it isn't currently in the best place, I'm not really interested in rewiring everything just to move it.
Old 04-06-2010, 08:06 AM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by Aage View Post
Hi all.
TIA,
Aage
Blue Sea Systems has lots to choose from. Switch to circuit breakers. I am in the process of replacing my panel right now.
Michelle TAC MT-0
Sarah, Snowball
Old 04-06-2010, 08:06 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
CB panels
I think that the best source is EBAY. A good selection, pictures to refer to and usually the best prices....usual EBAY cautions apply. I go to the boat section and I like Blue Seas items. After all...it is a Land Yacht.
Old 04-06-2010, 08:34 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
The people over at wiringproducts.com have several fuse panels to choose from. Some will also accept circuit breakers instead of fuses, or a mixture of fuses and breakers. They also have some neutral bus products on another page that may be helpful.
Fuse Blocks and Fuse Panels
Old 04-06-2010, 11:19 AM   #7
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
My experience has been that much better quality 12v panels, etc are found at marine supply dealers.
Here is an ebay item number for an example. - 330395319055
Regards,
Ken
Old 04-08-2010, 03:37 PM   #8
Ottawa , ON
Thanks, folks. Lots of good ideas!
I'll look at them all...
fuse panel, 12 Volt
Can't find the 12 volt fuse panel in my 1976 31 foot Sovereign clboyd Batteries, Univolts, Converters & Inverters 20 01-30-2009 06:02 PM
12 volt inline fuse stops power??? tinbender Vintage Kin 6 07-09-2008 04:37 AM
12 volt fuse box matilda Electrical - Systems, Generators, Batteries & Solar 2 06-27-2006 09:00 AM
Fuse panel bluebonnet Electrical - Systems, Generators, Batteries & Solar 7 08-15-2004 10:42 AM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
