Old 02-18-2007, 10:18 AM   #1
2005 16' International CCD
Ogden , Utah
Longer Battery Cables - Replace or Splice?
It's time to replace the group 24 battery on my 2005 16' CCD. I'd like to go to a group 27, but the existing cables don't reach. Does anyone have experience or advice, with replacing the cables vs. splicing with butt connectors and heat shrink? Seems like I'm trading off the risk of creating a leak (if I dig the cables out of the factory sealing where they go through the floor) against creating a poor electrical connection (loose crimp, corrosion, etc). Any advice?
RDM16CCD is offline   Reply With Quote
Old 02-18-2007, 10:24 AM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Replace the cables. Splicing them will work. However if you get any corrosion in the connection you will loose capacity. REplace them and be trouble free.
Michelle TAC MT-0
Sarah, Snowball
Old 02-18-2007, 12:09 PM   #3
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I'd replace the cables. I replaced one of mine last month. It took about an hour and a lot of reaching up under the couch on my trailer to disconnect it and reconnect the cable at that location. For me, I had to replace it because one cable had been cut off too short by someone. I had to take the positive cable off each time that I wanted to check the water level on one of the batteries.
If you are replacing all of your cables, I'm sure it will likely take you longer.
GStephens
GStephens is offline   Reply With Quote
Old 02-26-2007, 10:01 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I'd replace them if they were mine. It might be time to add new rubber covers also.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 02:12 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
61 Bambi Battery 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 05-21-2002 10:53 PM
Battery condition chart FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-31-2002 05:44 PM
