Old 08-30-2015, 12:34 PM   #1
2007 28' Safari
edmonds , Washington
locating inverter
Could someone tell me where the inverter would be located in a 2007 Safari 28? I see a on/off for an inverter below the monitor panel & battery status panel but am not getting any response when pushing the on/off button for inverter. Perhaps my trailer did not come with an inverter even though there is an on/off button?
Thanks!
texasmarshal is offline   Reply With Quote
Old 08-30-2015, 12:59 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
The answer to your question is varied. It mostly depends on who installed it. If you have the electrical knowledge, start at the fuse panel and follow the wires. The fatter wires should lead you to the converter as well as the inverter. Likewise, you can usually trace the wire from the batteries back to the inverter.
Another investigative direction - are you checking the appropriate outlet(s)? Not all 110/120 outlets will be supplied with power when the inverter is functioning. You may need to test every outlet to discover which is operating off the inverter and not shore power. A hint, but not necessarily always accurate, is to look for single 110 outlets rather than the double outlets.
A third possibility is the switch isn't for an inverter, but some other accessory like the water pump or water heater if the panel is wired like mine.
SeeMore is offline   Reply With Quote
Old 08-30-2015, 03:46 PM   #3
richw46's Avatar
Lexington , Kentucky
My inverter is in the same end of the trailer as the 110 inverter outlets and battery box; the front. Under the cushions of my L-couch is an access hole cut into the plywood. I think the inverter has to be within 3' of the battery box.
My inverter has 3 positions: On, Off and Remote. It will start from the remote switch only if the switch on the inverter is in the Remote position.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-30-2015, 04:43 PM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
It should be under your L sofa just forward of the water heater. There's probably a trap door forward of the hole to access the water heater bypass. If you open that door you should be able to access the inverter.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-30-2015, 05:19 PM   #5
aftermath's Avatar
Spokane , Washington
My inverter is under the bed.
I can activate mine through a wall mounted switch that is located in the galley just to the right of the stove. As previously mentioned, the inverter powered outlets are different from the regular outlets. I have one next to the television and one under the dinette table.
I don't turn anything on at the inverter. I just push the button on the wall to activate it. Hit the button again and it is off.
aftermath is offline   Reply With Quote
Old 08-30-2015, 05:22 PM   #6
richw46's Avatar
My inverter has a 3 way switch. Off, on and remote. If it's not set to remote the wall switch won't work.
-Rich
Rich & Yvonne
2004 4Runner SE
Help in locating my inverter... Woodyacme Batteries, Univolts, Converters & Inverters 9 03-12-2015 05:47 AM
Need assistance with water hookup locating airbassador Plumbing - Systems & Fixtures 9 08-31-2009 11:16 AM
Help Locating Part.... kneal General Interior Topics 4 03-04-2007 07:48 AM
Help needed locating thermostat for 96 Excella jasper2222 Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-17-2006 02:15 PM
Re-locating threads smily Forum Admin, News and Member Account Info 2 09-04-2002 05:30 AM
