Old 05-24-2015, 11:33 AM   #29
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by kry226 View Post
How do you do this? Just cut the line (where?), or possibly install an inline switch?
Don't think I'd ever want a permanent disconnection as there's always a chance one may need some charging from the TV.
ETA: Or is this only with a solar installation?
2 ways. The easiest is to just remove the fuse in the TV for the charge line. The second is as Switz described above. #2 is a bit more involved, but great if you tow other trailers that need the charge line to be active.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 05-24-2015, 11:53 AM   #30
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Thanks for the info, gents. Much obliged.
But again, we're only doing this when solar is installed, yes? Otherwise there seems to be little chance of overcharging with only the TV power.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 05-24-2015, 01:12 PM   #31
lewster's Avatar
Nope,
If you install Lifeline AGM batteries, the TV charge line needs to be disabled. I can't address other AGMs or liquid cells as I don't install them. Same with lithiums, but they need more sophisticated charging and would gave solar and inverter/chargers anyway.
Lew Farber
541-490-6357
Old 05-29-2015, 06:47 AM   #32
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Lithium Iron Phosphate Batteries
On the smart website I see a five year warranty and around $1200 for a battery. I pay $200 for two- two year Johnson controls 184 amp hour batts (total) that last usually around 3 years. Not counting having to change out chargers and controllers and adding monitors that same money provides 12 years of full replacement, 92 amp (50%) and 18 years of personally realized life each 2-3 years starting fresh with lead acid. I like AGM too but cost/life difference is important.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-04-2015, 05:12 PM   #33
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
One lithium fact that AM Solar shared with me was the long range cost of lithium battery replacement. Good news, a replacement cell is only $175 dollars, bearing in mind that it has to be brought into balance with the remaining cells before installation. That changes the long run cost considerably for the better.
Now, if you are younger than me, lifetime lithium costs in addition to future price reductions could make them the cheapest of all types of batteries. It may become more practical to keep your batteries when you trade or sell your Airstream. Also, future batteries may be made of aluminum and/or other material. Aluminum is being tested as I write. There will be all kinds of future cost reductions. Think ball point pens again.
guskmg
Lew, thanks for all your info on this subject. I can't think of a more exiting project as upgrading our Airstreams to your standards.
Old 06-04-2015, 08:21 PM   #34
2016 30' Classic
Erie , Colorado
Replacing a single cell is an interesting topic. Would like to see some more data on doing that in the configurations that we use. Besides the balance of voltage there are likely other factors that would affect how well it would play with the other older cells. Discharge rates, internal resistance, whether you are monitoring each pack with its own BMS (Battery Management Sensor) or monitoring a pack of cells with a single sensor to name a few.
Still lots to learn about these. So far I really like the setup that Marvin Braun from PrecisionRV did in my 2015 Classic. With full sun it looks like I can run the AC for about 4 hours if required solely from the lithiums (400ah). Throw a single Honda 2000 into the mix and it would nearly double the time.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 06-05-2015, 08:45 AM   #35
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Lithium batts
I brought up lithiums a while back and was blasted now it is a topic growing much more popular funny how things change here. Rand
grizbear is offline   Reply With Quote
Old 06-05-2015, 02:45 PM   #36
lewster's Avatar
You were just ahead if your time!!!
Lew Farber
541-490-6357
Old 06-05-2015, 07:38 PM   #37
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
One concern I have with the Lithium Ion is thermal runaway. The Boeing 787-8 initial woes come to mind as a big example.
I have been reading about Aluminum Ion which has similar and possibly superior capabilities to the Lithium, but is not yet commercially viable.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 06-05-2015, 09:00 PM   #38
lewster's Avatar
Lithium ion commonly refers to the formulation using cobalt. They did have thermal and other incendiary problems and gave lithiums in general a bad name. This is why we can't shop the (yet).
The formulation we use is lithium iron phosphate (LiFePO4). They are referred to as lithium phosphate batteries, or dimply 'LiPo'. Different chemistry and different characteristics.
Lew Farber
541-490-6357
Old 06-06-2015, 06:03 AM   #39
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thanks, Lew. That definitely makes a huge difference and raises the confidence factor.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 06-06-2015, 08:59 AM   #40
lewster's Avatar
[QUOTE=lewster;1632963]Lithium ion commonly refers to the formulation using cobalt. They did have thermal and other incendiary problems and gave lithiums in general a bad name. This is why we can't shop the (yet).
Sorry about the spelling! The phone likes to do it's own thing sometimes and if I don't proof read the message, this is what you get!! The message should have read:
Lithium ion commonly refers to the formulation using cobalt. They did have thermal and other incendiary problems and gave lithiums in general a bad name. This is why we can't ship them (yet).
The formulation we use is lithium iron phosphate (LiFePO4). They are referred to as lithium phosphate batteries, or simply 'LiPo'. Different chemistry and different characteristics.
Hope it makes more sense now!
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
Lithium Battery - 2012 doublebubble Batteries, Univolts, Converters & Inverters 23 08-05-2012 09:43 AM
Lithium ion battery sk8r29 Batteries, Univolts, Converters & Inverters 18 03-30-2011 01:33 AM
Spray Lithium Grease (Wal-Mart) Old_Town Hitches, Couplers & Balls 3 11-16-2007 12:48 PM
