Old 03-18-2018, 04:56 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Lithium Battery Discharge Question
I have a Battleborn Lithium battery (100 AH) and due to series of events beyond my control it has become almost totally discharged.
What are the consequences relative to the battery? Will it be damaged?
Thanks!
Old 03-18-2018, 07:18 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
The built-in battery management system is designed to prevent total discharge so you will be just fine.
https://battlebornbatteries.com/wp-c...-Cut-Sheet.pdf
Gotta love technology
wulfraat is offline   Reply With Quote
Old 03-19-2018, 09:15 AM   #3
2016 30' International
redondo beach , California
Thanks!
Tell more.
I have not tested the BB BMS (battleborn battery management system) on my two 100Ah ers.
I have gone as far as an indicated 95% discharge.
How far did you go?
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 03-20-2018, 08:24 PM   #4
Hans627's Avatar
Tavares , Florida
Originally Posted by mythbuster88 View Post
Tell more.
How far did you go?
I checked the battery with a volt meter and hardly got a reading at all. It was .17 or something like that. I thought the it was near zero from the reading. But I plugged it into the TV and in several minutes it "came alive" and the reading was 12.8 (which according to my state of charge chart is about 20% of remaining capacity).
So I am assuming the BMS was working as it should. I'm glad to hear that there is no permanent damage.
Old 03-21-2018, 09:47 PM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
As a suggestion when using a piece of test equipment such as a voltmeter a pre-check of the meter is always advisable. Looks like your meter was reporting something else.
sgschwend is offline   Reply With Quote
Old 03-22-2018, 06:22 AM   #6
Hans627's Avatar
Tavares , Florida
A good suggestion. Thanks!
Doesn't the explanation make sense? As in that should never happen? Just trying to learn about electrical things as it is one of my weak areas of knowledge.
Battery discharge question LOGRIDER Electrical - Systems, Generators, Batteries & Solar 1 01-18-2015 04:52 PM
TV battery discharge while plugged in? Peanut Electrical - Systems, Generators, Batteries & Solar 12 01-09-2015 05:34 AM
Battery Discharge bertheep Batteries, Univolts, Converters & Inverters 10 08-28-2011 09:07 AM
battery discharge wolf146 Batteries, Univolts, Converters & Inverters 11 04-24-2010 06:56 AM
battery: phantom load, or normal discharge? Chuck Batteries, Univolts, Converters & Inverters 12 08-25-2004 12:13 AM
