Old 08-05-2012, 07:55 AM   #21
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Wazbro View Post
Not sure if that makes a difference with lithium batteries, but they do use 2 separate batteries to run the car from in case the alternator quits.
It doesn't make a difference for lithium-ion batteries if you drain them fast (starting) or slow (house). I said they were starting batteries based on size. For lithium batteries there is a direct correllation between available amp-hours and battery weight (you can't finesse chemistry), and even two 6-pound batteries won't have the amp-hours to run much for long. Remember, in Nascar, if the alternator goes out and they start running on batteries alone, they can make a pit stop during the race to swap out batteries much easier than they can replace an alternator, so the batteries only have to last until the next pit stop.
Cats and ultraleather Airstream upholstery don't mix!
Old 08-05-2012, 10:20 AM   #22
1988 32' Excella
Robbinsville , New Jersey
Your right the 6lb battery probably wont last long, but a 25 or 28lb battery is 100 AH and $1299.99 (they list 2 different weights 28lbs might be shipping weight). Also 150 AH is 80lbs and $1699.99 or if you can afford it a 200 AH battery is 70.4lbs and $2299.99.
Lithium Marine Batteries
Old 08-05-2012, 10:36 AM   #23
JFScheck's Avatar
Rockville , Maryland
Images: 33
Clean-Tech Diesel is far superior too these Hybrid vehicles...
Oops - off topic...
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 08-05-2012, 10:43 AM   #24
The thread has morphed anyway. It was originally about the availability of lithium-ion house batteries at a reasonable cost, not about electric or hybrid cars.
I think we've established that lithium-ion batteries with enough amp-hours are available, but the price is still unreasonable in terms of dollars per amp-hour capacity. Though if you count the increased number of recharge cycles over an AGM and the relative ease of recycling, the life-cycle cost of lithium-ion may soon be competitive in terms of dollars per year of use.
