Old 08-18-2014, 09:27 PM   #1
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
Larger battery box
Has anyone replaced the standard tongue mounted battery box with a larger one suitable for golf card batteries (why doesn't Airstream make a slightly larger box?)
rp709 is offline   Reply With Quote
Old 08-18-2014, 10:20 PM   #2
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
As others have reported doing, we had a dealer modify the battery box height to accommodate golf cart batteries by removing the lid, adding C-channel, replacing the lid and repainting with factory paint. Looks original. Good question why Airstream does not offer this setup as an option, especially as part of a solar package.
field & stream is offline   Reply With Quote
Old 08-19-2014, 07:43 PM   #3
Grey Goose
2011 25' FB Flying Cloud
San Clemente , California
I recently had my battery box modified by the guy who installed my solar system. He cut the bottom off and spot welded in a lower bottom. The advantage of doing it this way is it doesn't add to the height of the box which will interfere with my front storage lid (I have a 25 foot FB with twin beds.
The battery box still looks original and the cost was about $200.
Ktholin is offline   Reply With Quote
Old 08-19-2014, 08:40 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Maybe because our Airstream Owners Manuals state that 10% of the trailer weight should be on the tongue, but never more than 1,000 pounds.
Doug and Cheryl
Old 08-20-2014, 06:30 PM   #5
rp709's Avatar
Battery box
I think Airstream is worried about added weight on the tongue and keeping the battery box smaller is their way of regulating that. I'm wondering if the original box can be removed and how expensive fabricating a new larger one would be. I do like the idea of lowering the bottom.
Old 08-20-2014, 09:57 PM   #6
Grey Goose
Lowering the bottom is an elegant solution. I'm very happy with it, and the look is entirely original. I estimate that changing out to two 6v golf cart batteries probably added 30 pounds. Just not enough to fret about.
Old 08-20-2014, 10:13 PM   #7
rp709's Avatar
golf cart
I have been using 2 Trojan 105 golf cart batteries for several years. This was a good addition. I added some hardwood spacers to raise the lid. I don't care for the look. Do you have pictures of the box modification?
Old 08-20-2014, 10:15 PM   #8
Grey Goose
I'll post what I can tomorrow.
Old 08-21-2014, 02:17 PM   #9
Grey Goose
Attached photos show 6V golf cart batteries in original battery box, maintaining top profile. Lowering the bottom can probably be done in a number of ways. In this case, two L brackets were welded to bottom with plate between.
Name:	ImageUploadedByAirstream Forums1408652206.362176.jpg
Name:	ImageUploadedByAirstream Forums1408652230.547074.jpg
Name:	ImageUploadedByAirstream Forums1408652260.901900.jpg
Old 08-23-2014, 07:17 AM   #10
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Nice. Thanks for that idea. I just went to all GC batteries in our sailboat and will be buying two for the AS in the next few weeks.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 07-29-2015, 02:32 PM   #11
fotoman1527's Avatar
2012 27' Flying Cloud
Miami , Florida
can't find a solution yet but working on it golf cart batteries instead of house batt
I'm going through this identical problem of trying to upgrade house batteries to golf cart batteries with a newly-acquired 2012 flying cloud 27. The Trojan T-105 RE batteries that the manufacturer says would be perfect for boondocking are a bit less than 2 inches too tall. A local welder says he can't do anything with a welded battery box, although I am going to email him pictures of the L-bracket solution in this thread.
I wonder if anyone has done an end run around this problem by locating robust golf cart batteries with a lower profile that fit in the existing box, without modification, or whether everyone who chose to upgrade their batteries to golf cart batteries has found someone to recraft their battery boxes.
Thanks!
fotoman1527 is offline   Reply With Quote
Old 07-29-2015, 03:15 PM   #12
1974 Argosy 20
Kooskia , Idaho
See post #18 on this thread for how I gained the height necessary for the Golf Cart type batteries.
http://www.airforums.com/forums/f449...-124829-2.html
Old 07-29-2015, 05:29 PM   #13
Miami , Florida
is there an alternative to expanding the battery box?
Thank you for your response!
I see that you added height to the top of your battery box:
"I mitered the corners and put small L brackets inside the channel for stiffness, then attached it to the top of the battery box with sheet metal screws (or pop rivets) then attached the original top of the box to the new frame."
If I add height on my flying cloud 27 battery box - AT ALL! - it will block access to the storage locker that sits next to the battery compartment. I hope you can see that in the enclosed picture.
I'm wondering if I put two of the largest batteries that can fit in the box as is that will dramatically increase my boondocking capabilities to a similar extent as using the Trojans. For example, a local battery store is recommending a pair of Group 31 Deep Cycle batteries, arguing they will give me "a considerable upgrade." They fit. I have to get the specs to compare. Has anyone gone that route? Do you have an opinion on the two choices? Thanks!!!!
Old 07-29-2015, 07:19 PM   #14
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Group 31's fit?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
Cracker box after cracker box. rebel beck Our Community 15 06-07-2006 07:53 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
