We built a custom stainless steel battery shelf and cover when we had four Lifeline 6ct 6Vdc 300 amp-hour batteries (92 pounds each battery) mounted above the original battery box that house the disc brake pump and controller for the Classic. That battery box assembly and four batteries was removed when we changed to one lithium iron phosphate 600 amp-hour battery that is mounted beside the Magnum under the Classic's front sofa. We dropped, the tongue weight nearly 200 pounds.
We are mounting a 300 amp-hour rated lithium iron phosphate battery in front of the street side wheel well under the side sofa along with the Magnum MSH3012 converter/inverter. This new battery actually weighs less than the two stock batteries that are removed from the front battery box. That existing battery box will become the storage space for the plastic wheel chocks and other very light small stuff.
