Old 08-03-2014, 06:54 PM   #1
1991 29' Excella
Rockwood , Ontario
Kill Switch Overheating
I heard a buzzing sound from behind the couch, I went to take a look and the few items I had behind the couch were very hot. I removed them and felt around the kill switch area and it was really warm. This put me into high alert mode, so I shut off the kill switch. It took about a minute and the buzzing stopped, it is now off.
Does this indicate a problem?? And what is it? And how can it be fixed? Do I need this on for city water while it is being used at home?
It was just in for service at the dealer, and some strange things are happening.
The lights above the door in front of the A/C were not working, and they re-wrapped some wires. I don't know if that would be connected or not to the overheating.
Has anyone had this happen with there kill switch? Or is that the batteries and inverter that are underneath the switch?
Thanks…as always!
breezyway is offline   Reply With Quote
Old 08-03-2014, 09:17 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Check batteries immediately. Check output of converter. May need to replace switch if bad/damaged. Loose connections can cause that. Unplug your converter till figuring it out.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-04-2014, 02:15 PM   #3
1991 29' Excella
Rockwood , Ontario
How Do I Check Batteries and Converter?
Ok, I am a newbie so not sure how to check batteries or converter. What should I do, I am willing to try.
Old 08-04-2014, 02:31 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
PM sent.
Channing
WBCCI# 30676
Old 08-04-2014, 02:39 PM   #5
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Heat is caused by resistance. Resistance can be caused by a bad connection at the switch terminals, or the switch could be bad. Find a friend who knows how to use a voltmeter and start testing the batteries, the converter, and all the wire connections. They do vibrate loose after a few years.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 08-04-2014, 04:04 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Electrical troubleshooting over the internet is notoriously unreliable and unsafe. There have been near misses, fires, burns, etc. Get someone qualified to take a look
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 01:59 PM
Kill Switch Question Dreamnair Batteries, Univolts, Converters & Inverters 8 08-14-2009 09:33 AM
umbilical and kill switch boondockdad Electrical - Systems, Generators, Batteries & Solar 9 10-25-2008 04:05 PM
master kill switch Deborah V Our Community 6 09-06-2004 07:43 AM
Kill switch for electric jack ? remark83 Jacks, Stabilizers, Lifting and Leveling 9 06-24-2003 10:14 PM
