05-25-2011, 08:36 AM
2006 28' Safari SE
Portland
, Oregon
Keeping batteries charged
I have a 2004 28' Safari SE. It's stored undercover in Portland, OR with no sun exposure. I recently bought a Honda 2000u generator. Can I keep the batteries charged during the winter by connecting and running the generator at regular intervals (say every 2-3 wks)? I'm trying to avoid removing the batteries and bringing them home. Finally, would a battery shut-off switch help in this effort?
05-25-2011, 09:02 AM
Naples
Your battery cut-off switch will certainly help isolate phantom loads from your batteries when in the 'store' position. Just remember to put it back to the 'use' position if you will be plugging the trailer into the Honda for battery charging. If you decide to use a separate battery charger plugged into the Honda and connect it right to the battery terminals, then you don't have to worry about the cut-off switch. I would NOT use the DC charging feature on the generator as it is only 8 amps and is not regulated.
A solar battery maintainer like this Battery MINDer product : BatteryMINDer Solar Charging System — 12 Volt, 15 Watt Panel, Model# SCC-015 | Battery Maintainers | Northern Tool + Equipment will work very well if you can secure it and have it face the sun. It has a fully automatic 3-stage charging section and will certainly maintain the 2 batteries that you have. I have installed several on units that go into storage and the feedback has all been positive.
You should also be aware that if your batteries are original, then they are probably approaching the end of their useful life.
lewster
05-25-2011, 10:23 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
If you don't have solar but have access to an electric outlet, you can also use the plug in version of the battery minder.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
07-14-2011, 02:06 PM
Wise Elder
2010 30' Classic
South of the river
If you have electric power at your storage location you can just leave the trailer plugged in.
07-14-2011, 03:53 PM
Oswego
Originally Posted by reshecca
The site says 1 to 5 batteries can be maintained with one BM. I use mine (same model) to maintain 2 group 29 batteries over the winter. No problem at all.
07-14-2011, 04:10 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
If you plug your trailer into shore power with a one stage charger, you will overcharge them and have to add water periodically. In recent years Airstream has installed one-stage converters to save a few bucks. This also can happen when you are plugged in at a campground and aren't using much power.
You can get various devices that have 3 stage chargers that solve this problem. My solution was to get a better, more sophisticated converter with a multistage charger. I don't need any add ons. My came from Iota as recommended by lewster, a Forum member who knows electricity. If you want to do this, you will probably have to cut off the front of the OEM converter to provide a way to screw the cover on.
Gene
07-14-2011, 07:17 PM
2010 20' Flying Cloud
Chico
Thanks for the info!
07-15-2011, 03:10 AM
2005 19' Safari
GLENDALE
, AZ
If you install a marine battery isolator switch to completely remove the batteries from all trailer phantom loads (like the propane alarm), they will hold a charge for several months. We have two Optima Blue Tops (group 24), and they are supposed to hold a charge for up to a year. However, the longest period our Bambi has set without taking it out has been 3-4 months.
I charge each battery separately overnight, once a month via the converter; and we don't worry about dead batteries freezing here in Phoenix. However, I wouldn't worry if I forgot to charge them for several months.
The only thing I have to worry about is someone turning on the light on the electric tongue jack, which is wired directly to one of the batteries. Someone turned the light on last year (probably kids), and I didn't see it for a couple of weeks, and one battery went dead. Wiring in an ON/OFF switch for the jack on the side of the battery box is one of the items on my TO-DO list.
07-15-2011, 04:58 AM
1965 17' Caravel
Birmingham
, Alabama
You could also leave the positive wire unhooked from the battery while in storage. You can get one of those inexpensive solar charging panels, run a long extension wire for it, and place it out from under the storage roof in the sun. I have the 5 watt panel from HF. Don't consider anything smaller in watt capacity. I hook my panel up about once a month early on a sunny morning and put it away again in the evening so it doesn't get stolen. This has kept my AGM maintained for a couple years now.
07-16-2011, 02:07 AM
2005 19' Safari
GLENDALE
, AZ
Note: Our Bambi is always connected to a 30-amp plug on the side of our house. To charge the batteries, all I have to do is turn the marine battery isolator switch to 1, 2 or BOTH, from OFF.
Once a month, when I come home from work, I turn the selector switch from OFF to 1. The next night, I turn it from 1 to 2. Then, the third night, I turn it back to OFF. This keeps the batteries topped off without overcharging them.
Being constantly connected to shorepower (with the battery switch set to OFF), we always have converter power for the lights and FantasticFans, or 110v for the air conditioner. Plus, since it's on the side of our house, we're always ready to pack up and go. Can't wait for retirement, but that's still a couple of years away!
07-17-2011, 12:36 PM
2005 30' Land Yacht 30 SL
Castro Valley
I left my 2005 LY plugged in over the winter, and Spring maintenance found low water in my two house batteries (3 yr old) from the built-in constant single-mode charger. I topped them up with distilled water & we headed up to the NorCal rally. Just before I exited from 101 to River Road we heard a loud "blam" from the front. Since it still steered okay it was not a blowout. An inspection showed that half the top of one of the house batteries had blown off! I'm guessing sulfation and maybe a clogged vent. The battery acid kept bubbling even with no charging or no load, very interesting. Now I'm back home with new batteries and a battery maintainer plugged in and the moho is NOT plugged in unless I need 120 v for tv or something. I added a second one for the chassis battery after it died, I think it was the OEM unit from the 2005 sale. Now a nice red top Optima should last me a while.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
07-17-2011, 12:57 PM
2008 22' Safari
Oracle
Gene
Hmmm, my recent 22' Safari came with the WFCO 3-Stage 8900 power center which has been working great. I would encourage the OP to determine what unit he has before going through extra effort.
07-17-2011, 01:16 PM
Trabuco Canyon
On mine an interior propane (?) detector will slowly drain the batteries even when the disconnect switch is off. I have AGMs and they seem to go months OK as long as I physically disconnect them by removing cables. On mine the easiest cables to disconnect are the two parallel cables with the thumbscrews. Both cables have to be removed to disconnect both batteries.
07-17-2011, 10:45 PM
2005 19' Safari
GLENDALE
, AZ
Tpi, with a marine battery isolator switch, all I do is turn the switch to OFF; and both batteries are completely disconnected from the trailer.
12-11-2011, 10:57 AM
2011 31' Classic
Nellysford
, Virginia
BatteryMINDer Odd Behavior?
Nice suggestion. Bought one. Attached to my two LIFELINE AGMs as instructed. During the day, when I'm not watching, the setting changes from 8A/AGM [left or top] to 2A/Gel [right or bottom], as shown in the two attached pictures. I can set it back to 8A/AGM, reconnect the batteries, and later in the day it will drop to the other setting.
1 - Is this something others have experienced?
2 - Will my pair of batteries be ready to roll on the 2A/Gel setting?
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
12-11-2011, 04:20 PM
Naples
Greg,
I use these quite a bit. If you find that the unit has returned to the default settings (2A/Gel), the unit has experienced an interruption in the AC power supply. They will stay as set if they see a continual 120VAC supply, but return to the lowest setting as a safety measure if the AC power is withdrawn for any reason.
They are excellent for charging Lifelines, but you have to be sure that they are set on AGM.
lewster
12-12-2011, 07:09 PM
2011 31' Classic
Nellysford
, Virginia
Lewster,
Thanks so much for your response. My first reaction, like you, was that we had a power outage. I thought that was the problem, too. So I reset things and went about my yard work. LO and behold it reverted again in a short time. I'll have to take a closer look.
12-12-2011, 07:42 PM
Naples
Lewster,
Greg,
It's also possible that your batteries are too low in voltage (below the threshold) to be re-charged by the BatteryMinder. The unit will NOT re-charge a dead battery which is below a certain voltage threshold, which IIRC is about 11VDC.
If the batteries are above this, you might actually have a defective unit. I would then call the company and get their tech support line and discuss the problem with them.
lewster
12-13-2011, 09:26 AM
2011 31' Classic
Nellysford
, Virginia
Lewster,
Yep, I read about and know the unit will not restore bad batteries. These LIFELINES are new in May from JC, have been on the road pretty much constantly since then, and were checked with a meter before I set them up for winter storage.
Last night, thinking there was something amiss with my parallel wires and clips, I attached the unit to a single battery with the same mystifying results.
I have just sent an email to techsupport@vdcelectronics.com along with the pictures. Hope to hear something soon. Thanks for your encouragement and support.
