Old 05-04-2015, 05:23 PM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Keep tripping GFI
I have my AS Bambi (2000) plugged into my garage, 20amp circuit. It has been doing fine since January, then today it started tripping the GFI on the garage circuit. I checked to be sure the AC and refrigerator are not on as I know they can draw too much current for the 20 amp plug. The only thing I did today was wash the trailer. Is it possible I got water somewhere that is causing a short circuit? Any suggestions as to how I can trouble shoot this?
Cameron
curnes is offline   Reply With Quote
Old 05-04-2015, 05:39 PM   #2
richinny's Avatar
2011 34' Classic
check the outside outlet for moisture along with the outlet in the fridge compartment.
Ricky
Old 05-04-2015, 05:41 PM   #3
1979 23' Safari
Wayland , New York
Probably got some water in the plug or in the adapter from 30A to your house plug. It doesn't take much water in either to trip a GFCI. Could have sprayed some in there with the hose very easily. Possibly splaching up into the back of the refrigerator vent. The baffles in there are designed for rain not hose spray directly. One reason I wish the electrical input connections tended to be more weather tight considering where they are used. Check inside the trailer for tripped breakers. If none you probably got some water where it shouldn't be. Give it some time to dry out and give it a shot.
Old 05-04-2015, 05:48 PM   #4
1987 25' Sovereign
Oregon , Ohio
It most likely is water where it should not be, but if it persists it could be that the GFCI needs replacement.
msmcv51 is offline   Reply With Quote
Old 05-04-2015, 05:49 PM   #5
1976 31' Sovereign
Oswego , Illinois
Had that happen, dead cell in bat. replaced prob cured. Bad bat. was 4 mos. old.
Old 05-04-2015, 06:27 PM   #6
curnes's Avatar
Thanks everyone who replied. I'll let everything dry out thoroughly and try again tomorrow afternoon. Cameron
Old 05-06-2015, 08:32 PM   #7
curnes's Avatar
Dried things out and everything is working just fine. No more tripping GFI. Not sure where I caused the problem, my guess in the refrigerator connections. Thanks again for your feedback. Cameron
Old 05-06-2015, 08:37 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I suspect the outside 120V outlet very easy to get damp and trip the GFCI.
Garry
Old 05-06-2015, 10:08 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Where did you find water?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-07-2015, 05:35 AM   #10
z , North Carolina
Yup
I would definitely be chasing the source of that issue before it comes back to bite you in the ...
Inspect the power inlet to insure a watertight seal. If it's coming in now, it's not going to seal on it's own. It could be a faulty GFI, but given the symptoms you describe, you're getting moisture/water in/near your power source. Don't let that lil electrical gremlin raise its ugly head when you need your electricity the most.
Test all of your GFI outlets too. Good hunting!
Gavin
FishinHatteras is offline   Reply With Quote
Old 05-07-2015, 06:04 AM   #11
Gainesville , Florida
At least it's good to know the gfi circuit is working properly. Jim
new power supply now tripping GFI housebg Batteries, Univolts, Converters & Inverters 32 04-16-2009 01:15 PM
GFI tripping altamont Batteries, Univolts, Converters & Inverters 19 09-04-2008 11:22 AM
Dometic RM100 tripping GFI tschat Refrigerators 3 08-21-2006 09:01 PM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
GFI Tripping grizzy Electrical - Systems, Generators, Batteries & Solar 3 09-07-2004 06:17 PM
