Old 09-30-2015, 11:21 AM   #1
2014 30' Flying Cloud
Moorestown , New Jersey
Keep Refrigerator on electric while traveling
Has anyone rewired the refrigerator to electric via the inverter while traveling. We have gone up to 10 hours on the road and all gets hot without cooling. The LP or electric option works fine when still, but not while traveling.
We have ordered a 2016 30' Classic for the spring and want to modify it before delivery.
thanks
Fred2 is offline   Reply With Quote
Old 09-30-2015, 11:26 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Still under warrenty? Your fridge should work fine using gas underway.
MICHAEL
Old 09-30-2015, 11:40 AM   #3
runnersg's Avatar
2016 27' Eddie Bauer
TX , Texas
Mine always gets hot on LP while traveling. Very frustrating
2016 Eddie Bauer 27'
runnersg is online now   Reply With Quote
Old 09-30-2015, 11:52 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We have run every RV for years and this new one is no exception on LP while moving.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 09-30-2015, 11:57 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless there has been a change in the law your frig should work on gas while o the road.
Are you seeing a "check" light when you stop indicating the gas has failed?
2004 Excursion 4x4
Old 09-30-2015, 12:20 PM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Ours gets warm while traveling and running on propane.
I have about decided it simply doesn't stay lit.
I have come to believe it lights, runs until it blows out, re-lights, and then repeats.
Just enough not to give an error on the display.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-30-2015, 12:36 PM   #7
HowieE's Avatar
Images: 12
I guess the first question that needs to be answered is how well does the frig working on gas, while parked, compare to it working on electric, while parked.
If they are similar then we have to figure a way to record the run time ratio while on gas and traveling.
The first thing that comes to mind would be a 12 volt LED light visible from the TV that is wired across the gas valve. That light should not go out unless the proof of flame circuit detected a blown out flame.
2004 Excursion 4x4
Old 09-30-2015, 12:37 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Maybe check your regulator pressure. If it is low, your fridge will not cool well!
It should be cold, even while in transit.
Old 09-30-2015, 01:57 PM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
JD
Not sure what your rig is, but is it one that needed the baffle shroud recall work done on it?
Mine stays lit on the highway.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-30-2015, 02:10 PM   #10
HowieE's Avatar
Images: 12
Originally Posted by GCinSC2 View Post
JD
Gary
Interesting point. While the recall shroud did not address flame blow out it would be interesting to know if the original flame cover is in fact in place. Without that you would have blow out problems.
2004 Excursion 4x4
Old 09-30-2015, 02:15 PM   #11
jdalrymple's Avatar
Jay , Oklahoma
Our refer cools fine on both fuels when parked.
It has all the baffles in place and is unmodified.
Just a contrary pain the butt.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 09-30-2015, 02:37 PM   #12
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
thanks
This would require getting an electrical circuit from your inverter to the area behind the fridge. Some people (including us) who have changed out the Airstream provided inverter and charger/converter have hooked up all of the trailer outlets to the inverter giving us the ability to power all the outlets in the coach off of the inverter when not plugged in to shore power. The problem with running the Dometic fridge off of the inverter is that it draws well over 50 amps when operating which will deplete your battery very quickly. In short, it's not practical or desirable to run the Dometic dual fridge off the battery, plan on using the propane.
Bob Martel
WBCCI# 5766
Old 09-30-2015, 04:23 PM   #13
HowieE's Avatar
Images: 12
Think you are off by a factor of 10. The heating element in the frig is between 300 and 500 watts depending on the size. Thus the current draw is closer to 4 amps.
2004 Excursion 4x4
Old 09-30-2015, 04:24 PM   #14
CRH
1995 25' Excella
xxxxx , xxxxxx
X2....I had to adjust mine recently.
CRH is offline   Reply With Quote
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 03:34 PM
Refrigerator on while traveling? electrodx Member Introductions 17 11-13-2007 03:59 PM
Where do you keep your bird when traveling? 68 Overlander The Pet Forum 3 05-19-2005 05:54 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
