09-30-2015, 11:21 AM
2014 30' Flying Cloud
Moorestown
, New Jersey
Keep Refrigerator on electric while traveling
Has anyone rewired the refrigerator to electric via the inverter while traveling. We have gone up to 10 hours on the road and all gets hot without cooling. The LP or electric option works fine when still, but not while traveling.
We have ordered a 2016 30' Classic for the spring and want to modify it before delivery.
thanks
09-30-2015, 11:26 AM
Biloxi
, Mississippi
Still under warrenty? Your fridge should work fine using gas underway.
MICHAEL
09-30-2015, 11:40 AM
2016 27' Eddie Bauer
TX
Mine always gets hot on LP while traveling. Very frustrating
2016 Eddie Bauer 27'
09-30-2015, 11:52 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
We have run every RV for years and this new one is no exception on LP while moving.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
09-30-2015, 11:57 AM
Princeton
, New Jersey
Unless there has been a change in the law your frig should work on gas while o the road.
Are you seeing a "check" light when you stop indicating the gas has failed?
2004 Excursion 4x4
09-30-2015, 12:20 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Ours gets warm while traveling and running on propane.
I have about decided it simply doesn't stay lit.
I have come to believe it lights, runs until it blows out, re-lights, and then repeats.
Just enough not to give an error on the display.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
09-30-2015, 12:36 PM
Princeton
, New Jersey
I guess the first question that needs to be answered is how well does the frig working on gas, while parked, compare to it working on electric, while parked.
If they are similar then we have to figure a way to record the run time ratio while on gas and traveling.
The first thing that comes to mind would be a 12 volt LED light visible from the TV that is wired across the gas valve. That light should not go out unless the proof of flame circuit detected a blown out flame.
2004 Excursion 4x4
09-30-2015, 12:37 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Maybe check your regulator pressure. If it is low, your fridge will not cool well!
It should be cold, even while in transit.
09-30-2015, 01:57 PM
2007 30' Classic S/O
Somewhere
, South Carolina
JD
Not sure what your rig is, but is it one that needed the baffle shroud recall work done on it?
Mine stays lit on the highway.
Gary
09-30-2015, 02:10 PM
Princeton
, New Jersey
Originally Posted by GCinSC2
JD
Gary
Interesting point. While the recall shroud did not address flame blow out it would be interesting to know if the original flame cover is in fact in place. Without that you would have blow out problems.
2004 Excursion 4x4
09-30-2015, 02:15 PM
Jay
, Oklahoma
Our refer cools fine on both fuels when parked.
It has all the baffles in place and is unmodified.
Just a contrary pain the butt.
Regards,
JD
Jeff & Cindy
09-30-2015, 02:37 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
thanks
This would require getting an electrical circuit from your inverter to the area behind the fridge. Some people (including us) who have changed out the Airstream provided inverter and charger/converter have hooked up all of the trailer outlets to the inverter giving us the ability to power all the outlets in the coach off of the inverter when not plugged in to shore power. The problem with running the Dometic fridge off of the inverter is that it draws well over 50 amps when operating which will deplete your battery very quickly. In short, it's not practical or desirable to run the Dometic dual fridge off the battery, plan on using the propane.
Bob Martel
WBCCI# 5766
09-30-2015, 04:23 PM
Princeton
, New Jersey
Think you are off by a factor of 10. The heating element in the frig is between 300 and 500 watts depending on the size. Thus the current draw is closer to 4 amps.
2004 Excursion 4x4
09-30-2015, 04:24 PM
1995 25' Excella
xxxxx
, xxxxxx
X2....I had to adjust mine recently.
09-30-2015, 04:35 PM
2007 25' Classic
Hutto
I think the 50A estimate was for the 12v supply from the battery. If the fridge really is 500w, 50A is in the ballpark, considering inverter and wiring losses.
09-30-2015, 04:55 PM
Princeton
, New Jersey
Touche'
2004 Excursion 4x4
09-30-2015, 05:49 PM
1967 22' Safari
Space Coast
Hello, before my Airstream we had a new 2000 Lance 1010 truck camper with a Dometic 3 way fridge. We took it all over the East coast and a 43 day cross country trip from NY to CA with the unit on LP. In all that time the fridge shut off once or twice when it was very windy out. If yours keeps shutting down, I would have it checked out by an RV service place.
Good luck.
Sam.
Ps. we are having problems with the fridge in our '67 AS Safari the thermostat is leaking LP. Im going to get it repaired or I'll replace it.
09-30-2015, 06:08 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
I installed a Magnum MSH inverter/charger in my new Classic. With the 4 6V Lifeline's and the 30 amp Magnum I can (and have) run my Dometic on 120V while on the road. If it's a sunny day and the 6 100W solar panels are working hard, it really is no problem to run the Dometic on electric instead of gas. The question is why? It cools equally well on either gas or electric....and since it is designed to cool with propane, I made the call to just run it on gas. I do have a separate 120V circuit that's wired to my ice maker, which I leave turned on if I need ice cubes. My intent in designing the electrical set-up was to have flexibility, and it works to that end. Let's not get into the cost of the Magnum, the batteries, the sub-panel, all that copper wire, solar panels, controller, etc. If I'd done a cost-benefit analysis I probably wouldn't have taken on this project. Or even bought an Airstream in the first place!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
09-30-2015, 06:47 PM
2005 19' Safari
GLENDALE
, AZ
09-30-2015, 08:34 PM
Chelsea
, Michigan
Perhaps 4 AH on AC, but on DC it's over 50 AH. Since he will be getting his AC from an inverter running off his 12 volt DC batteries, the draw on his 12 volt DC batteries will be in the range of 50 AH.
Bob Martel
WBCCI# 5766
